but a really big, complex package like OpenJDK is way above my pay grade, sorry. You’d need to know what you were doing. If you know your way around Java then creating .hpkg files should be child’s play. It really is just marginally more complex than making a zip file from the command line.
Thanks both for the information. I forgot to mention about those guides, I tried them as well!
It looks like I was doing it right, but there’s an issue with the most recent nightly. Any idea what might be causing this issue and how it can be resolved?
I couldn’t download the hpkg you linked, the download link on that page points towards another location that does not exist.
[quote=CyberneticianDave]Thanks both for the information. I forgot to mention about those guides, I tried them as well!
I couldn’t download the hpkg you linked, the download link on that page points towards another location that does not exist.[/quote]
Must be a Web+ bug, because it works ok in Windows, but not in Haiku VM on the same machine. Didn’t even think to download it on the PC. Just not sure how to get it over now, without VMware Tools installed… lol!
There’s been a bug in web+ concerning downloads that Adrien has fixed since the last release (I think). For the time being, try “wget” from the Terminal.
I have tried to install the above hpkg on a gcc4Hybrid hrev46642, but it does not work
Install is fine, muCommander runs ok, but TF Write does not have any area to enter text, Calc stars forever and have same problem (also seems to hang). Show works fine,
[quote=pistooli]I have tried to install the above hpkg on a gcc4Hybrid hrev46642, but it does not work
that’s most likekly because you’re using the vesa driver,i’ve had this and i forgot to file a bug report,the problem goes away by using a native driver.
please file a bug report about this.
[quote=kim1963][quote=pistooli]I have tried to install the above hpkg on a gcc4Hybrid hrev46642, but it does not work
Any ideas, what am I doing wrong?
Many thanks.[/quote]
hrev46642 x86 (gcc4-2)
[/quote]
I have not said that it does not work at all. I am simply curious what shall I do to make it work on my computer.
[quote=khallebal]that’s most likekly because you’re using the vesa driver,i’ve had this and i forgot to file a bug report,the problem goes away by using a native driver.
please file a bug report about this.[/quote]
Thanks khallebal!
How can I verify if I am using a native driver or not?
There were some binary incompatible changes in a recent revision, so current OpenJDK builds won’t run on the latest nightlies.
Over the last month or so I’ve bootstrapped the build on a recent nightly and have been slowly merging in the jdk7u updates. There are a few remaining issues I’d like to fix, but once I’m done I’ll release a package.
