Hi all, i bought last year a new Notebook (Schenker Slim 14) sadly my Wifi is not supported and it looks like it will not be supported for a long time sind eve Freebsd means that it possible need a complete new driver. So i am searching for a supported m.2 2230-Module with E-Key. Any hints which module will be supprted by haiku?
Intel 7260 and 6235.
Keep in mind there is a known bug: if you boot with UEFI enabled some otherwise supported card wont work (the driver cant upload the firmware or something similar). Use legacy boot, both card should work.
UEFI doesnt work at all anyway.
Without safemode it appserver will crash while somehow trying to set the resolution to something above 2570 x … and with safemode enabled it kdls.
