Have the Haiku R1Alpha3 Anyboot.Image but not sure how to burn it to CD. Haiku website shows use SimplyBurns but that does not want to mount or see the anyboot.image as valid. Tried OS X Disk Utility also but that does not like anyboot.image files.
Only way to make one is from ISO image and tried that but my new Zotac system that installed and runs R1 Alpha 2 fine does not want to install R1 Alpha 3. Starts install process after booting from CD, starts install on my one Be partition (that is all I have), and then a few minutes later all this text shows in the screen is it freezes.
In R1 Alpha 2 nothing like this happens.
So, something about R1 Alpha 3 has issues.
Trying to download the ISO again “just in case” and make a new ISO burn from OS X but if that fails, not sure what else to try. This time trying the newest nightly build instead of the stock R1 Alpha 3.
TJ
