hi
i don’t know what i’m doing wrong,but when i try to configure the haiku source following this guide http://www.haiku-os.org/guides/building/gcc-hybrid, i get this:
Welcome to the Haiku shell.
~> cd haiku/haiku/generated.x86gcc4
~/haiku/haiku/generated.x86gcc4> …/configure --alternative-gcc-output-dir …/generated.x86gcc2 --cross-tools-prefix /boot/develop/abi/x86/gcc4/tools/current/bin/
…/configure: line 382: cd: …/generated.x86gcc2: No such file or directory
~/haiku/haiku/generated.x86gcc4> cd …
~/haiku/haiku> cd haiku/haiku/generated.x86gcc2hybrid
bash: cd: haiku/haiku/generated.x86gcc2hybrid: No such file or directory
~/haiku/haiku> …/configure --alternative-gcc-output-dir …/generated.x86gcc4 --cross-tools-prefix /boot/develop/abi/x86/gcc2/tools/current/bin/
bash: …/configure: No such file or directory
~/haiku/haiku> cd …
although the folders exist and are correct i keep getting this msg.
is there a bug in the latest nightlies? any help would be apreciated.
i’m using the rev:38837 gcc4hybrid.
It looks like you didn’t make this directory before starting to configure your build.
mkdir haiku/haiku/generated.x86gcc2hybrid
should fix this error
remove the:
–cross-tools-prefix switch
make sure you have those directories already made.
I think that’ll fix it for you.
hi
thanks guys i finaly got it build(btw tonestone57 you must add the --cross-tools-prefix switch otherwise you get a “invalid argument” error msg.
but now i have another question:
how do i get the bluetooth & the other 3rd party software built with the source,especialy the bluetooth.
i tried with all availble configure options from the guide,like (–3rdparty – multiuser)but at the end all i get is a normal nightly.
so i don’t know what i’m missing.
i’d apreciate your help.
thanks.
you need UserBuildConfig file.
go into build/jam subfolder. Look at UserBuildConfig.*
Rename UserBuildConfig.sample to UserBuildConfig & edit as needed.
List of Optional Packages you can get Haiku to build with:
http://dev.haiku-os.org/browser/haiku/trunk/build/jam/OptionalPackages#L13
Important line of UserBuildConfig optional packages are those below:
Add the optional packages to the image
AddOptionalHaikuImagePackages WonderBrush BePDF WebPositive Pe ;
leave space between last package & semi colon & make sure the line is not commented out.
