Hardware configuration
Hey there,
I need to throw some parts together and and run the TUneTracker automation system.
I would appreciate a cheap list of components that work great with haiku. I’ve looked at the database on haikuware but those are old components that can’t be purchased anymore.
I have to have a computer that just works. I need to setup a radio station and dealing with any major issues is not going to help me in this process.
Let me know if there’s any hardware I should avoid
Thanks in advance
Konstantin
It might be best to contact Tunetracker directly, as they are the the ones that would know best. Or you could ask on the haiku mailing list. Most of the TuneTracker people subscribe.
http://www.freelists.org/list/haiku
