Haiku's IRC channels are moving to OFTC! | Haiku Project
After being present for more than 20 years on the Freenode network, we are moving our IRC channels to the OFTC IRC network!
This is a companion discussion topic for the original entry at https://www.haiku-os.org/news/2021-05-19_haiku_is_moving_to_oftc/
Will there be channel logs available for this new network as well?
Not yet established. At least we have not yet found a service that logs any OFTC channels yet…
Does anybody have a description of how to set-up vision to connect to the new irc server?
just change chat.freenode.net / irc.freenode.net to irc.oftc.net
Does not connect atm? Is Server on?
64bit Haiku is working 32bit not yet.
What is that / in the server name? I think it should not be there.
I have personally tested this on 32bit Haiku and can tell you that it is working fine.
I made a similar mistake. The port for a ssecure connection is 6697, not 6667.
Oh strange, yes it is working now thx humdinger.
I think he means change the address from either chat.freenode.net or irc.freenode.net (depending on what you have in your config) to irc.oftc.net. That´s how I interpreted it anyway :wink:
You can find a short guide on how to configure Vision for the OFTC network and how to register your nickname in the blog post Registering your nickname for IRC.
