HaikuPorts repo on R1Beta4 does not refresh
Recently, I am getting this message from SoftwareUpdater when trying to check for updates.
"Refreshing repository “HaikuPorts” failed.
Any idea why?..thanks!
Check the pinned topic. : )
I am getting this on a fresh install. Running R1Beta4 under UTM (QEMU) emulator.
Yes,this is expected,Beta 4 can’t be updated anymore as long as the transition to Beta 5 is in progress,and afterwards you should update to Beta 5.
The project doesn’t have the capacities to run repository servers for two releases at the same time.
Ok…I just read that thread. Got it, thanks!
I sucessfully updated my repos to Beta5 and did a full-sync. However, now I lost all my screen resolutions…just the 1280x
Any ideas?..thanks!
what is the PCI ID for your graphics card? You can find it in listdev or from the devices preferences.
I figured it out…I just needed to change the Display config for my UTM VM…thanks!
