To make ratings viable as a basis for promoting software to HaikuDepot’s “Featured packages” tab, there have to be a lot of them. Up to now there are too few…
Therefore, I propose a March 4 Ratings… on this 4th of March…
Open the HaikuDepot app, check only the “Installed packages” in the “Show” menu, and go through your list of apps. If you haven’t rated/commented on an app in this list, consider doing it now!
Also a good opportunity to remove stuff you installed and forgot about; spring-cleaning, if you will…
