Hi all, hope you are all having a great start to March! kallisti5 has put together a survey to help determine the priorities the Project should focus on for the immediate future. If you haven’t already, we would really appreciate if you filled out the survey - it is 100% anonymous and you do not have to enter any personal details.
You can fill out the survey here.
I really think that as soon as WebKit/Web+ are fully working with hardware acceleration, multimedia features and developer tools, then its really a moment one can switch. Also Electron-based applications will start working then and there are a lot of modern tools which will be supported then.
Chromium (and Electron) is based on the Blink engine from Google. It is originally a fork of WebKit but the two projects are separate since 2014. So, the WebKit port does not help a lot in getting Chromium or Electron apps working.
