I want to install HAIKU on my system. The PC is set up in a multi-boot
configuration and I need to configure a partition for HAIKU,. but I need
to know what filesystem type to configure to boot from.
Also what are the different filesystems that HIAKU can work with?
Use BeFS. If your current OS cannot format a partition to be BeFS, make a FAT partition with a unique partition label, then use DriveSetup on a live Haiku USB stick to format it to BeFS.
