Haiku, R1/Beta3 Test Candidate 1 is now available.
This is a testing image to ensure functionality of Haiku R1/Beta3 on various end user systems.
Warning: This is not the final R1/Beta3 release and should not be used on “long term” systems. This is a testing images of our codebase that will eventually become R1/Beta3.
Changes since Test Candidate 0:
Set HAIKU_OFFICIAL_RELEASE for release logos
intel_pstates fix
Resolves lockups on some intel platforms
Minor posix confstr adjustments
sdhci bug fixes
add haiku bootloaders to /boot/system/data/platform_loaders/
Enables easier access to the latest copy of our bios/EFI/pxe bootloaders on running systems
The deskbar crashed on shut down two times but worked fine. On the first boot (before the background wallpaper showed up) I have enabled “show application expander,” that might be the reason.
Both VMware add-on packages do not work.
The open sound driver is working.
The mouse pointer behaved funny a few times at first, switching the mouse control to the host then back to haiku fixed it when it happened.
Can’t boot it on my machine, but then haven’t been able to boot a nightly for a while either so not sure I want to interrupt the beta3 process with that!
I will once I’ve found some useful details (unless spec is enough for now) - I’ve not been able to get any useful output or find any combination of settings that makes a difference yet! Jessicah suggested some older builds prior to the UEFI refactor, will give those a spin and report back.
Installed the TC from a usb stick with no issues, and it has been stable thus far. The only thing that I’ve seen of note was after installing, I ran software updater and it listed updates to 55181+16 which I ignored.
I ran software update this morning and there was nothing listed, so it appears it’s been corrected.
Minor UX suggestion.
May want to update the instructions at:
From the First boot
If I choose Install Haiku instead of Try out Haiku
there is no path back to the desktop to copy the UEFI files.
The Quit button is changed to Reboot.
hmm. i’ve seen this one before as well booting from EFI on non-x86 platforms.
I’m working though generating a new set of initial_packages for haikuporter to get the webkit2 port running, but will circle back to this one right after to try and identify the cause.
Were you booting as UEFI via the anyboot as a CD or a USB stick?
