Haiku on VAIO VGN-TXN15P
Just wanted to report that I was able to install and now run in native resolution Haiku on a Sony Vaio TXN15P. This is an Intel Core Solo 1.2 GHz laptop.
Screenshot of it:
http://yfrog.com/55haikuvaioj
Sound and wired network works. Screen works at 1366x768 (set with boot menu).
Wifi does not work (but I used the alpha, not the nightly build).
No bluetooth.
Fn key works for some functions (Pg Up, Pg down), but not the special laptop ones.
Overall very impressed with the Alpha build.
Upgrade to nightly and post a report please. It looks great.
Instalei o Haiku alpha 1 no meu laptop Dell Vostro 1510 core 2 Duo 1.8 - 2gb.
Problema na inicialização. O Haiku para de carregar na parte de Plug-in card (initializing Device Maneger). Esse erro faz aparecer o prompt> mas digitando continue a inicialização continua normalmente.
Problema com a placa de vídeo Intel x3100, resolvi o problema, delete intel_extreme /boot/system/add-ons/kernel/drivers/bin/
Wifi e sd-card não funciona como todos já sabem.
Algumas teclas de função também não funcionaram.
De resto tudo funcionou e está rodando em dual boot com o Vista - gerenciador de boot GAG.
Achei muito divertido e muito bom o Haiku, estou divulgando.
Estou aprendendo a usar e testando bastante.
Very good work.
And what will the Beta.
Lukaio - Recife - Brasil.
Ikshaar, what video card does your laptop have?
This laptop is using Mobile Intel 945GMS Express AFAIK
I will try Alpha2 now…
Haiku R1 Alpha 2 not installed and the problem with the video card continues.
BAD.
Here a video of Alpha1
www.youtube.com/watch?v=FrSpav0Z3pY
Tomorrow publish a video problem with the Alpha2
Just finish the install of Alpha 2 up and running. Now with wifi with WEP.
I forgot how to make permanent the screen resolution settings that you select in boot manager, anyone ?
