Hello and thanks for the support.
Kim 1963
That link is for another OS, I have Ubuntu.
Maybe I can share that with my neighbor.
Max-Might
This is what I have been reading about the “nightlys”:
“The Haiku source is continually built by a dedicated machine. These “nightly images” are provided mainly for development and testing purposes. You can download and install these snapshots to check out the latest features and bugfixes, be aware though that they may be unstable at times.”
I am thinking I should get the November 2012 release and then update.(?)
Also “https://www.haiku-os.org/guides/installing/making_haiku_usb_stick” is where I have been going from and the result is I get “something” on the USB Flash but it does not seem to be an “image” and when I plug it into another machine it is merely ignored.
I have tried do the instructions as per the above link and also with Unetbootin.
I am on an older version of Ubuntu. I have put ISOs on CD and I have put ISOs on USB. I am still a beginner but when there are instructions I usually muddle my way through - not this time.
The USB Flash is formatted to FAT32 and located at /dev/sdb
What is WRONG with the Official Version? Is the security out of date?
What is “written directly” mean?
"universal anyboot - can be burned to compact discs, written directly to USB sticks, or used with QEMU."
Does it mean I can skip downloading to my computer and download to the USB flash drive?
Fresh start this a.m.
Go to terminal to follow instructions at “https://www.haiku-os.org/guides/installing/making_haiku_usb_stick”
Here are the results with the USB Flash Mounted according to the “Disk Utility”:
me@ferg-VII-160:~$ umount /dev/sdb
umount: /dev/sdb is not mounted (according to mtab)
Here are the results with the USB Flash NOT Mounted according to the “Disk Utility”:
Next:
me@ferg-VII-160:~$ dd if=path/to/haiku-anyboot.image of=/dev/sdb bs=1M
dd: opening `path/to/haiku-anyboot.image’: No such file or directory
Then:
dd if=path/to/haiku-r1alpha4.1-anyboot.image of=/dev/sdb bs=1M
dd: opening `path/to/haiku-r1alpha4.1-anyboot.image’: No such file or directory
OK START OVER
I have downloaded "haiku-r1alpha4.1-anyboot.zip"
Do I “extract” it to the USB?
Do I “extract” it to a file?
Do I “extract” it AT ALL?
Image of haiku “extracted” to USB:
</home/ferg/Desktop haiku on USB Flash Drive with properties.png>
USB connected to another Ubuntu laptop;
reboot and click boot from USB Flash drive - results:
“NOTHING”
The cursor at the top of the left side of the screen rapidly blinks as the flash drive is slowly dimly flashing as though it is dieing.
Actually the above sentence describes me - I am all revved up to try this thing and the hope fades to a dim very dim despair and disappointment.
