Haiku on Prodesk
Yo, I’m getting a HP prodesk 400 g2 as a exchange for some random broken mini pc. It’s a model from 2017, it uses a realtek alc211. Is realtek alc221 supported on Haiku? Audio is crucial.
Yes, the realtek alc211 is supported through Haiku’s built-in Intel High Definition Audio (hda) driver. Hope it helps! Make sure to use the 64-bit version for the best chances.
Thank you for the help, I accidentally wrote realtek 221 as 211, but I still appreciate the help.
