Hi all,
I just tried Haiku Beta5 on a Microsoft Surface Pro 4.
Wifi does not work.
Do I have any option to try and make it work?
Or should I just give up for now?
Cheers!
Hi all,
Wifi does not work.
Cheers!
What are PCI vendor/device IDs?
https://cgit.haiku-os.org/haiku/tree/3rdparty/korli/haiku-current.list
device id is 0x2b38
device vendor is 0x11ab
Looks like mine is not supported.
Bummer.
Thanks.
Something obscure that is not supported in *BSD (Haiku networking drivers are mostly ported from *BSD): Marvell Technology Group Ltd. 88W8897 [AVASTAR] 802.11ac Wireless
Got a spare USB port? Some USB wifi dongles are supported now.
Ah, I got one lying around.
Unfortunately, no luck NetGear WNA1100 Wireless-N 150 [Atheros AR9271]
I will try to find a compatible dongle on the 2nd hand market.
Thanks,
cheers!
OpenBSD
The device is supported by OpenBSD versions 4.9 and newer:
It can be ported to Haiku.
CC: @waddlesplash
I am available to help testing the thing.
I haven’t ported any OpenBSD USB drivers yet, so this would probably need a bit of work at least.
Ok, given that dongle is huuuge and old, don’t think it worths the time.
Thank you all.
Cheers
