Hi everyone! Long time admirer of Haiku - had it running on my old 2008 MacPro and loved it.
Recently picked up a GPD Micro PC, with an Intel 4100 and 8gb of RAM, Intel integrated GPU pushing to a 6" 1280×720 display.
Was able to boot from the internal microSD slot I cloned the Haiku install disc onto - everything works great except for the screen, which it is displaying as if it were a vertical monitor (with 720x1280 resolution). You can see what I’m talking about here:
Doesn’t seem to be any orientation option in the Screen app, wondering if anyone has any clue as to how I might be able to fix this. Really want to be able to run Haiku on this thing!
thank you for the reply! I will try to send it to an external monitor and see how that goes.
