yoku28
April 13, 2021, 10:14am
1
This is my very first use of haiku ( I mostly used linux). I tried to boot for arm and followed the blog post
https://www.haiku-os.org/guides/building/compiling-arm
Host system: Ubuntu
Installed the qemu-efi package for ubuntu
Trying to boot for arm as mentioned:
$ qemu-system-arm -M virt -m 1024 -bios /usr/share/qemu-efi/QEMU_EFI.fd -device virtio-gpu -hda haiku-mmc.image -hdb haiku-minimum.mmc
Result:
It launches QEMU , but nothing is seen (no logs or any activity on QEMU).
Please let me know if it boots haiku for virt board ?
thanks,
yoku
That is the current status of the ARM build. It does not work.
yoku28
April 14, 2021, 12:16pm
3
Partially correct. In the blog it says
You can remove the “-hdb haiku-minimum.mmc” to see our bootloader menu on arm
Be sure to examine the uart console in QEMU for debug data from our bootloader / kernel.`
I would expect both of this when I launch qemu (atleast some logs of bootloader menu)
X512
April 14, 2021, 12:27pm
4
Here ARM Haiku on Qemu can run boot loader, show splash screen and load kernel.
yoku28
April 14, 2021, 1:42pm
5
thanks, the arm stuff is too much into early stage and is difficult to understand when there is no much exposure to UEFI, bootloaders etc. Ubuntu, fedora, opensuse etc have all different parameters for qemu boot.
I will leave it for now after trying multiple options on my ubuntu machine as it is too much of trial and error.
