i had setup Haiku (32bit-nightly build) on a Dell optiplex 755 usff.
I had to change the hard drive and tried install it again (both 32 & 64bit nightly) but in vain. The problem is again the intel_extreme driver (i got the same white screen with error during loading intel_extreme driver). How can override this and proceed with setup?
In the past, did you have a normal screen (with icons), or the same white screen? Rudolfc is working on the Intel driver , because i had only a blank screen.
