After I installed some apps I got a very long menu and I have to scroll to find my searched app.
Does it be possible to re-organize the menu with some main menues like in other OS? Perhaps “System, Utilities, Network, Office, etc”, to get a better overview.
https://besly.de/index.php/en/preferences/pattering-the-haiku-menu
And on https://software.besly.de are my tool “MenuSorter”
Is there the program Menu Sorter for Haiku 64 bit?
I lost my source code. if interested, I can try to recreate it for 64bit. But that can take a while
The address https://besly.de
doesn’t work.
Unfortunately I need a 64bit app. Doesn’t matter.
You can do it manually.
Good day,
@muffin, while the Menu Sorter software is not available for 64bits, Besly also has a tutorial on how to arrange your Menu hierarchy (https://besly.de/index.php/en/preferences/pattering-the-haiku-menu).
And this is the result:
It doesn’t take that much time to rearrange it. You can give it a try
Regards,
RR
I have complete the 64bit version, but i need to solve 2 little bugs before.
One problem stay on the end, you need to add every new installed program into the menu by hand (or Menu Sorter).
