Haiku İntel Centrino Wireless-N 2230 Driver
Hello, is there any way to make this wifi-card work under haiku?
WHY DO YOU EVEN OPEN A FORUM IF YOU WONT EVEN HELP?
http://www.haiku-os.org/forums/haiku/user_support_forum
Hi!
I don’t think moving the question to another forum will help anymore than yelling. If nobody has an answer at the moment, there won’t be a reply.
Regards,
Humdinger
Sorry, for my disrespecting attitude…
No harm done, Ege. :slight_smile:
Regards,
Humdinger
Hi Edge there could be a way.
If you can find a freebsd driver wich support the intel centrino N 2230 then you can try to compile this driver for Haiku.
Haiku has a compatibiltiy layer for Freebds so this is your chance to get the intel wireless-n 2230 running
The other chance is to write a own driver for haiku but to port the freebsd/ openbsd driver makes more sense :slight_smile:
