Everything is working , thanks to the x201 not having a webcam
Lan working
Wlan working
Brigthness and Audio Buttons are working
Touchpad and Trackpoint are working
Lan working
Wlan working
Nice, but why should the webcam be a problem?
All the Laptop/Notebook I use have webcam and no problem booting HAIKU.
Which audio buttons do you mean?
But the webCam doesn’t work. Not a problem if you don’t need it, but technically you can’t say it’s 100% supported. The “100% supported” label is a bit silly depending on the laptop.
For example, mine has not only a webcam, but also a card reader (for bank cards or similar), a fingerprint reader for unlocking, an infrared scanner, a neural network accelerator, …
I don’t really need any of that. But I can’t say the machine is 100% working and fully supported.
That (no webcam, so no unsupported webcam) is what i meant, but i really like the working audio and brightness buttons, unfortunatly for x220 onwards they are no longer working (x61 working, x301 working, x201s working)
