Not sure where to put this really.
I noticed that there is no official build of haiku with gcc4, so I set out to make one myself. Built on Xubuntu 8.04.
I thought I might save some of you the time required to build haiku with GCC4, so I am posting it here.
This is a raw disk image, useable in qemu (not sure about other emulators, I use qemu) only 128mb in size, so you may want to make another disk image to work on.
Thanks for putting that up, I’ve been trying to make a gcc4 build for the last couple of days, and cant seem to get anything to compile correctly, I have a thread trying to get gcc 4.3.3 working but no replys yet.
Seems to be about the same to me, then again, both were tested on an old dell dimension 8100 with a P4 1.4ghz processor (Mind you, it took about 8hrs to get the dev tools, compile, get the source, compile, and build a disk image), not exactly a powerful computer by today’s standards.
I don’t think you will see massive speed changes either way.
debian is way more lightweight and I would say archlinux is lighter than debian… especially if you are wanting to save disk space on an older machine ubuntu is not the way to go
Whoops, double post.
Also, mind you, clock speed isn’t the only determinant. My laptop with a 1.5ghz pentium m can decode 720p video, this one can’t, and it’s only 100mhz slower.
Ups, Sorry, this not a GCC2 problem. Look, image have 400 MB and have all packets (dev. too), is 2 MB place free , and FF need more free place when starts. I compiled larger image and upload to net.
