Haiku B5 32 bit repos
Is anyone else having issues reaching the HaikuDepot repos?..thanks!
https://eu.hpkg.haiku-os.org/haiku/master/x86_gcc2/current
https://eu.hpkg.haiku-os.org/haikuports/master/x86_gcc2/current
From your links,haiku works and haikuports throws an Error 403.
The 403 for HaikuPorts is expected; directory listings are disabled on that server. The repo file exists and can be downloaded, though.
Thanks for the replies…it turned out that my Ethernet config got messed up (no idea how)…I was able to reset the adapter and now it works. Repos seem fine.
This is a VM I have under VMWare.
