Haiku audio output
Hi installed haiku on my laptop and all seems to work fine.
But have an audio issue, audio only works from the headphone jack, no sound from the speakers.
The sound preferences don’t show any options, there’s any way to change this ?.
HDMI audio output?
Is a laptop computer, sounds only is output from the headphones jack.
But no audio comes from the speakers on it.
I had that happen on my desktop PC as well. Audio went to “front panel” jack, but no output to the line-out on the back.
No idea how hard it would be to implement “jack selection” on current drivers, but would be nice to have.
In the meantime, @soviet9922, you could open a ticket over dev.haiku-os.org, attaching the output of the listdev command, and a copy of your /var/log/syslog file.
Hi soviet9922, same situation on my laptop.
It’s a problem with the driver. If i remember correctly, the manufactor of the laptop can add the output line to the sound chip in different solution. To optimize the driver, its a lot of work to do that.
Regards lorglas.
