Get haiku a native bootloader so new users can install it. without having too guess what to doo.
Hi and thanks for the suggestion. What is the problem you would like to be solved? We might already have a solution.
https://www.haiku-os.org/docs/userguide/en/applications/bootmanager.html
https://www.haiku-os.org/docs/userguide/en/bootloader.html
Sorry i forgot about this question and about that i have this account. Thank you for answer. I need to try it again. Do you think it wił run on Old netbook tom n270 1g ram?
32-bit Haiku might run. 64-bit generally recommends at least 2 GB of RAM.
Both versions should run just fine with 1gb of RAM.
Note that 64bit won’t run on your netbook, the N270 is a 32bit only CPU.
