- → In case Dell Precision M6700
Haiku R1B4 and R1B5 / Nightly used my integrated Intel video of Intel core i7 3rd gen extreme edition CPU
The nvidia card 8GB then was not supported by Haiku, now I have 2 failing memory on 2 banks of 4 banks of RAM memory - so this laptop is on reserved state until I can purchase 4 x unbuffered ECC RAM for that laptop - I want ECC ti have that if I have RAM issue. Last time it was not obvious, and not saved my config and data.
I just write as I could live with then, and now I cannot check the existing new nvidia driver is OK for me, as the affected system has memory failure in 2 banks. One I could get out, but the other is under the keyboard and other stuff I would not start to remove. I rather changed to a newer Precision I bought with totally another purpose.
- → In case Dell Precision M6800
Haiku R1B6 / Nightly uses my integrated Intel Iris video of Intel core i7 4th gen extreme edition CPU
I opened a ticket, to check my AMD card can be included into the supported ones of radeon_hd driver. It has in the config by its ID as one of our forum member helped to identify,
but by the driver config that ID belongs to another card/chip actually, than mine exactly.
Now I am awaiting patiently to check someone check my ticket with more skill regarding the videocard/chip – what is the solution ? update the config, add my card/chp to the config ? or anyway, my HW not supported ?
In case Dell Precision M6400
When I bought the M6800, I could not buy in Red Covet Edition I wanted, I saw a cheap M6400 its age Orange Covet Edition.
I can use it in Haiku x86 and x86_64 with VESA framebuffer video driver, as
seems the integrated Intel GPU is disabled in the Core2 Quad Extreme CPU.
It is not a BIOS setting, I checked it, no shuch part in the BIOS to select video card or disable video card in the Precision M6400, and only AIDA64 reported this HW piece. If it was disabled, then Intel should do it, but the AIDA64 also can fail related to this ‘feature’.
The dedicated GPU - Nvidia Quadro FX 3700M - unfortunately not supported by Haiku.
Against that I have native resolution display 1920x1200 with VESA framebuffer driver on both Haiku 32 bit and 64 bit as well. The issue is with mouse input devices and not anything else.
Even the Dell docking station works, I had to use to get PS/2 port for the Hungarian keyboard that was found in this flat I am now.
So this way I could write I’m not eagerly waiting / wanting card support for HW accelerated any.
I would be satisfied if a Haiku driver would available for my VGA cards/chips in my machines, and not just a SW solution would separate me from a black monitor and no displaying at all under Haiku. However until this solution works I’m happy, as all games I would rarely play work with VESA framebuffer too.
I know, browsers can be benefit from accelerating stuff, if such browsers exists in Haiku.
Actually in 32 bit Haiku none such browsers, those were available actually cannot be installed due to some package conflicts - required version of one library cannot be provided actually. Others just ported for 64 bit Haiku only.
We need patience - to finally spin itself out – that’s all.
