Ahoy @Nighthawk !
I forgot to check is changed anything toward my CPU in listdev output, however meanwile I upgraded to hrev59860 , so the patch in hrev59856 could have effect, if core i7 and Xeon also contained in that patch regarding CPU info.
Let’s see - is this changed listdev’s output →
user ~/Desktop 04:14 listdev
device Bridge (Host bridge) [6|0|0]
device 0c04: Xeon E3-1200 v3/4th Gen Core Processor DRAM Controller
device 0c01: Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller
vendor 1002: Advanced Micro Devices, Inc. [AMD/ATI]
device 6640: Saturn XT [FirePro M6100]
device aac0: Tobago HDMI Audio [Radeon R7 360 / R9 360 OEM]
device 0416: 4th Gen Core Processor Integrated Graphics Controller
device 0c0c: Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller
device Serial bus controller (USB controller, XHCI) [c|3|30]
device 8c31: 8 Series/C220 Series Chipset Family USB xHCI
device Hub (Unused, Full speed (or root) hub) [9|0|0]
vendor 0000: Unknown
device 0000: Unknown
vendor 05e3: Genesys Logic, Inc.
device 0608: Hub
device Human Interface Device (No Subclass, None) [3|0|0]
vendor 046d: Logitech, Inc.
device c52b: Unifying Receiver
device Mass Storage (SCSI, Bulk-Only) [8|6|50]
vendor 0781: SanDisk Corp.
device 5595: Unknown
vendor 04e8: Samsung Electronics Co., Ltd
device 6300: Unknown
device Communication controller [7|80|0]
device 8c3a: 8 Series/C220 Series Chipset Family MEI Controller #1
device 153a: Ethernet Connection I217-LM
device Serial bus controller (USB controller, EHCI) [c|3|20]
device 8c2d: 8 Series/C220 Series Chipset Family USB EHCI #2
vendor 8087: Intel Corp.
device 8008: Integrated Rate Matching Hub
device Video (Video Streaming) [e|2|0]
vendor 1bcf: Sunplus Innovation Technology Inc.
device 2984: Unknown
device 8c20: 8 Series/C220 Series Chipset High Definition Audio Controller
device 8c10: 8 Series/C220 Series Chipset Family PCI Express Root Port #1
device 8c14: 8 Series/C220 Series Chipset Family PCI Express Root Port #3
vendor 14e4: Broadcom Inc. and subsidiaries
device 43b1: BCM4352 802.11ac Dual Band Wireless Network Adapter
device 8c16: 8 Series/C220 Series Chipset Family PCI Express Root Port #4
device 8c18: 8 Series/C220 Series Chipset Family PCI Express Root Port #5
device 8c1c: 8 Series/C220 Series Chipset Family PCI Express Root Port #7
device 8c1e: 8 Series/C220 Series Chipset Family PCI Express Root Port #8
device Generic system peripheral (SD Host controller) [8|5|1]
vendor 1217: O2 Micro, Inc.
device 8520: SD/MMC Card Reader Controller
device 8c26: 8 Series/C220 Series Chipset Family USB EHCI #1
device 8000: Integrated Rate Matching Hub
device Application Specific Interface (Device Firmware Update) [fe|1|1]
vendor 413c: Dell Computer Corp.
device 8143: Broadcom BCM20702A0 Bluetooth
device Chip/SmartCard () [b|0|0]
vendor 0a5c: Broadcom Corp.
device 5800: BCM5880 Secure Applications Processor
device 8c4f: QM87 Express LPC Controller
device Mass storage controller (SATA controller, AHCI 1.0) [1|6|1]
device 8c03: 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode]
device Serial bus controller (SMBus) [c|5|0]
device 8c22: 8 Series/C220 Series Chipset Family SMBus Controller
As you can see hostbrige, PCI bridge, HD Audio controller device still reports as Xeon 3th/th generation core
If the patch is referred to Haiku’s About window, that always was correct identifying the CPU in my all machines I booted Insrtaller images (32/64 bit).
fastfetch - I assume use dmidecode - write the processor correctly.
user ~/Desktop 04:33 fastfetch
MMMM MMMM user@HiQ_R1Nitely_512GO
MMMM MMMM -----------------------
MMMM MMMM OS: Haiku R1B6- x86_64
MMMM MMMM Host: Precision M6800 (01)
MMMM .ciO| /YMMMMM*" Kernel: Haiku R1~beta5+development
MMMM .cOMMMMM|/MMMMM/` Uptime: 28 mins
, ,iMM|/MMMMMMMMMMMMMMM* Packages: 1459 (hpkg)
`*.__,-cMMMMMMMMMMMMMMMMM/`.MMM Shell: bash GNU bash, 5.3.15(1)-release (x86_64-unknown-haiku) verzió
Copyright (C) 2025 Free Software Foundation, Inc.
A licenc GPLv3+: a GNU GPL 3. vagy újabb változata
<http://gnu.org/licenses/gpl.html>
Ez egy szabad szoftver, terjesztheti és/vagy módosíthatja.
NINCS GARANCIA, a törvény által engedélyezett mértékig.
Display (AUO): 1920x1080, 60 Hz
DE: Application Kit
WM: Application Server
Font: Noto Sans Display Regular (17pt) [Plain / Menu / Bold], Noto Sans Mono Regular (17pt) [Mono]
Terminal: Haiku Terminal 1.0.0
Terminal Font: JetBrainsMono Nerd Font Propo (22pt)
CPU: Core™ i7-4800MQ (8) @ 2.69 GHz
GPU 1: AMD Radeon HD 8950
GPU 2: Intel 4th Gen Core Processor Integrated Graphics Controller
Memory: 3.55 GiB / 31.91 GiB (11%)
Swap: 0 B / 31.91 GiB (0%)
Disk (/DATA_MEDIA): 160.25 GiB / 256.00 GiB (63%) - bfs
Disk (/SANDSK256GO): 212.70 GiB / 234.84 GiB (91%) - bfs
Disk (/data_shared): 10.62 GiB / 29.89 GiB (36%) - fat [External]
Local IP (/dev/net/ipro1000/0): 192.168.1.217/24
Battery (DELL 4HJXXD1): 123%
Battery:
Battery:
Locale: hu.UTF-8
hw-probeshows the same
user ~/Desktop 04:40 hw-probe -all
Probe for hardware ... Ok
Reading logs ... Ok
Local probe path: /boot/home/config/non-packaged/data/HW_PROBE/LATEST/hw.info
user ~/Desktop 04:40 ls -l /boot/home/config/non-packaged/data/HW_PROBE/LATEST/hw.info
total 18
-rw-r--r-- 1 user root 5040 júl. 18 04:40 devices
-rw-r--r-- 1 user root 406 júl. 18 04:40 host
drwxr-xr-x 1 user root 2048 júl. 18 04:40 logs
user ~/Desktop 04:40 cat /boot/home/config/non-packaged/data/HW_PROBE/LATEST/hw.info/host
arch:x86_64
boot_mode:BIOS
cores:4
dual_boot:0
dual_boot_win:0
hwaddr:ACA66517F781B3D0DC573F9992EC6E44
haiku_version:hrev59860 Jul 17 2026 06:28:39
kernel:R1~beta5+development
microarch:Haswell
model:Precision M6800
probe_ver:1.6
sku_number:Precision M6800
sockets:1
system:haiku-hrev59860 Jul 17 2026 06:28:39
system_version:hrev59860 Jul 17 2026 06:28:39
threads:2
type:laptop
vendor:Dell Inc.
year:2015
user ~/Desktop 04:41 cat /boot/home/config/non-packaged/data/HW_PROBE/LATEST/hw.info/devices
pci:1002-6640-1028-05cd;03-00-00;failed;graphics card;;Advanced Micro Devices, Inc. [AMD/ATI];Saturn XT [FirePro M6100];Dell
pci:1002-aac0-1028-05cd;04-03-00;detected;sound;;Advanced Micro Devices, Inc. [AMD/ATI];Tobago HDMI Audio [Radeon R7 360 / R9 360 OEM];Dell
pci:1217-8520-1028-05cd;08-05-01;detected;card reader;;O2 Micro, Inc.;OZ777 SD/MMC Card Reader Controller;Dell
pci:14e4-43b1-1028-0017;02-80-00;detected;network;;Broadcom Inc. and subsidiaries;BCM4352 802.11ac Dual Band Wireless Network Adapter;Dell
pci:8086-0416-1028-05cd;03-00-00;failed;graphics card;;Intel Corporation;4th Gen Core Processor Integrated Graphics Controller;Dell
pci:8086-0c01-1028-05cd;06-04-00;detected;bridge;;Intel Corporation;Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller;Dell
pci:8086-0c04-1028-05cd;06-00-00;detected;bridge;;Intel Corporation;Xeon E3-1200 v3/4th Gen Core Processor DRAM Controller;Dell
pci:8086-0c0c-1028-05cd;04-03-00;detected;sound;;Intel Corporation;Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller;Dell
pci:8086-153a-1028-05cd;02-00-00;detected;network;;Intel Corporation;Ethernet Connection I217-LM;Dell
pci:8086-8c03-1028-05cd;01-06-01;detected;storage;;Intel Corporation;8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode];Dell
pci:8086-8c10-1028-05cd;06-04-00;detected;bridge;;Intel Corporation;8 Series/C220 Series Chipset Family PCI Express Root Port #1;Dell
pci:8086-8c14-1028-05cd;06-04-00;detected;bridge;;Intel Corporation;8 Series/C220 Series Chipset Family PCI Express Root Port #3;Dell
pci:8086-8c16-1028-05cd;06-04-00;detected;bridge;;Intel Corporation;8 Series/C220 Series Chipset Family PCI Express Root Port #4;Dell
pci:8086-8c18-1028-05cd;06-04-00;detected;bridge;;Intel Corporation;8 Series/C220 Series Chipset Family PCI Express Root Port #5;Dell
pci:8086-8c1c-1028-05cd;06-04-00;detected;bridge;;Intel Corporation;8 Series/C220 Series Chipset Family PCI Express Root Port #7;Dell
pci:8086-8c1e-1028-05cd;06-04-00;detected;bridge;;Intel Corporation;8 Series/C220 Series Chipset Family PCI Express Root Port #8;Dell
pci:8086-8c20-1028-05cd;04-03-00;detected;sound;;Intel Corporation;8 Series/C220 Series Chipset High Definition Audio Controller;Dell
pci:8086-8c22-1028-05cd;0c-05-00;detected;smbus;;Intel Corporation;8 Series/C220 Series Chipset Family SMBus Controller;Dell
pci:8086-8c26-1028-05cd;0c-03-20;detected;usb controller;;Intel Corporation;8 Series/C220 Series Chipset Family USB EHCI #1;Dell
pci:8086-8c2d-1028-05cd;0c-03-20;detected;usb controller;;Intel Corporation;8 Series/C220 Series Chipset Family USB EHCI #2;Dell
pci:8086-8c31-1028-05cd;0c-03-30;detected;usb controller;;Intel Corporation;8 Series/C220 Series Chipset Family USB xHCI;Dell
pci:8086-8c3a-1028-05cd;07-80-00;detected;communication controller;;Intel Corporation;8 Series/C220 Series Chipset Family MEI Controller #1;Dell
pci:8086-8c4f-1028-05cd;06-01-00;detected;bridge;;Intel Corporation;QM87 Express LPC Controller;Dell
usb:046d-c52b;03-00-00;detected;human interface;;(Logitech, Inc.);(Unifying Receiver)
usb:04e8-6300;08-06-50;detected;disk;;(Samsung Electronics Co., Ltd);
usb:05e3-0608;09-00-00;detected;hub;;(Genesys Logic, Inc.);(Hub)
usb:0781-5595;08-06-50;detected;disk;;(SanDisk Corp.);
usb:0a5c-5800;00-00-00;failed;;;(Broadcom Corp.);(BCM5880 Secure Applications Processor)
usb:1bcf-2984;00-02-00;failed;;;(Sunplus Innovation Technology Inc.);
usb:413c-8143;00-01-01;failed;bluetooth;;(Dell Computer Corp.);(Broadcom BCM20702A0 Bluetooth)
usb:8087-8000;09-00-00;detected;hub;;(Intel Corp.);(Integrated Rate Matching Hub)
usb:8087-8008;09-00-00;detected;hub;;(Intel Corp.);(Integrated Rate Matching Hub)
bios:dell-a13-01-29-2015;;works;bios;;Dell Inc.;BIOS A13 01/29/2015
board:dell-0xwc1m;;works;motherboard;;Dell Inc.;Motherboard 0XWC1M
cpu:intel-6-60-3-core-i7-4800mq;;works;cpu;;Intel;Core i7-4800MQ CPU @ 2.70GHz
mem:hynix-hyundai-hmt41gs6bfr8a-pb-sodimm-serial-9fa8c954502834f5155a08118f9c043b;;works;memory;;Hynix/Hyundai;RAM HMT41GS6BFR8A-PB 8GB SODIMM DDR3 1600MT/s
mem:samsung-m471b1g73eb0-yk0-sodimm-serial-5eeaf18c668b01bd4527096e9a5ffb00;;works;memory;;Samsung;RAM M471B1G73EB0-YK0 8GB SODIMM DDR3 1600MT/s
mem:samsung-m471b1g73eb0-yk0-sodimm-serial-778f743295b299ba163582bbbbacd296;;works;memory;;Samsung;RAM M471B1G73EB0-YK0 8GB SODIMM DDR3 1600MT/s
mem:samsung-m471b1g73eb0-yk0-sodimm-serial-bf813be8d0cce5e9f5e696a2ccfa506e;;works;memory;;Samsung;RAM M471B1G73EB0-YK0 8GB SODIMM DDR3 1600MT/s
user ~/Desktop 04:42
I may be wrong and that listdev write Xeon CPU cores at that 3 device items is quite normal, I just remembered, and found as a interesting why not core i7 and core i7 extreme as I had in my previous M6700 that was a cire i7 Extreme CPU. There also this Xeon cores were written on devices.
