[GSoC 2024] Virtio Sound: Final Report | Haiku Project
During this GSoC period, I focused on developing the virtio sound driver for Haiku, aiming to enhance its performance as a guest OS in virtualized environments. This journey began with some challenges, for example, initially, I missed a small detail in the driver module path, which prevented the driver from loading.
This is a companion discussion topic for the original entry at https://www.haiku-os.org/blog/diegoroux/2024-08-22_gsoc_2024_final_report
Thanks a lot for your contribution! Hope you can stick around a bit longer to do follow ups here. :100:
Thanks for your contribution to Haiku and for the detailed report that was very interesting to read.
Thanks! Beside improving user experience in VM, as a good part of upcoming sound drivers will probably use hmulti_audio, I’d say that your guide itself is priceless.
You create documentation based on your findings, could you explain what is missing in the documentation and unclear points?
Hi, @marcoapc.
While working on this driver, I can truly say to you, that a lot of time went into understanding hmulti_audio.
If you try to search of any documentation of multi_audio, you’ll likely come across (although even trying to find this back took me a little while) this mail thread: ā€œ[…] I’m afraid no spec documentation is available, reading the sources might help. […]ā€ and a link to an old newsletter.
The ā€œcompleteā€ documentation for the driver API is included in three files: multi_audio.h, multi_audio.gb, and multi_audio.txt . To get these files, write to trinity [at] be [dot] com
Only multi_audio.h remains, the others are sadly lost to time.
While the newsletter gives a bit of information about BUFFER_EXCHANGE, it only serves at that. Everything else, shall be inferred from previous drivers and multi_audio code.
Some structs, contain members of which I thought to be important and even defining for what other members should be read, are completely ignored. (See flags in BUFFER_EXCHANGE, playback_latency, record_latency, etc.)
While reading multi_audio.h helped a lot, if you only keep that, you’d never know that B_MULTI_GET_ENABLED_CHANNELS and B_MULTI_SET_ENABLED_CHANNELS are actually required to be implemented; multi_audio.h only warns about B_MULTI_SET_GLOBAL_FORMAT as required to be implemented.
Many little cases like the above exist.
But I think I went a bit long. I hope I cleared it up!
I do happen to have that file right here. What I do not have anymore, is a working copy of GoBe Productive to open it and convert it to something else.
Here’s the zipped multi_audio.gb. (not sure how long it last online… used the first site that worked for me).
Edit: seems the above auto-deletes after the first download :slight_smile:
Here’s a different one that should last for 6 days at least.
Why not use 0x0.st?
It has my IP range blocked for some reason.
https://0x0.st/XtoI.gb.zip/multi-audio.gb.zip
Great job, thank you.
You have clarified a lot, thank you very much for your work and time dedicated.
Ahoy @leavengood ,
Is there a chance you know this trinity from Be Inc. ?
I’m asking because he possibly could provide the third file :–> ``multi_audio.txt`
Only this 1 file is missing from the mentioned 3 files now - if you followed the conversation above.
Thanks in advance
if you can make Diego’s work easier to better understand / able to re-create/complete documentation about ā€˜multi_audio’ driver and the driver itself.
Kind regards`
I found multi_audio.txt file, look @diegoroux :
Seriously, what are the chances this would work? They wrote this file 25 years ago. Do you hold on to documentation for things you worked on in a past job a quarter of a century ago? I certainly don’t (well, I have not been in this job for 25 years, but even if you asked me about things I did 10 years ago, that all stayed at the company when I left)
Well, fortunately it is not needed anymore.
I understand your reasonig too - I may not composed my sentence well.
I should have write to ask about file availability …
Mea culpa !..
multi_audio.gb converted to pdf
https://file.io/nxQwynIhjUb2
The transfer you requested has been deleted.
https://drive.google.com/file/d/1erb53cAopbZfLw0fODcl2pCLEbHAD3zR/view?usp=sharing
