Ahoy Daniel ( @dalmegnu ) !
Well, It’s a far better status, than as it was before your work … I mean as nothing existed in the hardware virtualization support in case Haiku … this way it’s a nice progress in my eyes as well
Hurrah !
So, I think, this way it’s more momentous to do such many small finery toward those you mentioned, than introduce SVM (AMD) part too, besides SVX (Intel)… so lot more important that implemented code should work well , is it true ?
… If I understood all well from your blog post
From introductory to report #2 - I summarized to grock it …
→ Port the NVMM driver
¤–> Frontend : complete
¤–> Backend for SVX (Intel) : complete, all the 16 IOCTL calls done,
¤–> Backend for SVM (AMD) : very early state
→ Port libnvmm
¤–> compiled successfully - port completed
¤–> test suite is ported and all tests pass
→ NVMM – extend with SLAT on Haiku natively
¤–> EPT tables support (Intel) :
support for them is complete and it works
page fault handler is integrated into Haiku’s virtual memory
subsystem
¤–> NPT tables support (AMD) : missing ?
→ Make QEMU port capable of accelerating virtual machines
¤–> QEMU supports NVMM acceleration already, no work needed
¤–> latest QEMU - with a patch -
+ detects NVMM acceleration availability, and compile
- actually it doesn’t work, something breaks
As I see more things completed
than
failed or missing -
Especially if we do not visit
your TODO list on Github :D, I agree that is something …
Have a good coding time and happy days of resting as well if your moods and feels it needs to later freshly sit back to your desk !..
Chase away your concerns !..
… and if you have no so much time after this 2024 GSOC period ends … you may want to complete it on next year’s summer !..
