QEMU is a virtual machine which allows running an operating system inside of another. While there already is a Haiku port, it currently does not support any acceleration system through native virtualization (through Intel VT-x and AMD SVM.) This makes it too slow for many uses.
This project aimed to bring hardware virtualization to Haiku by porting NVMM, a hypervisor that already has QEMU support, into Haiku from DragonFlyBSD. The project goals (as included on the proposal) were:
Thanks for the summary - however I followed the blogpost – it was great to read again your journey through the porridge mountain of adding a hypervisor solution to QEMU on Haiku …
It would be completed - yes,
it is going to be merged - yes ! -
… especially as it also to helps Haiku and app development , …
as it will make it possible to install/boot
Haiku images of PPC, ARM/ARM64 or Risc-V architecture
on an x86_64 Haiku. with almost bare metal speed !
For end users - like me - will also possible to try out other OS images - just as we do / did it on another OS.
Or … to have a nightly running … on Haiku Beta :))
Thank you for your efforts until now -
and in the future : to clean/complete this whole solution.
Just to clarify: the only images you can accelerate with hardware virtualization are those of the same arquitecture as your machine. So no accelerated Haiku RISC-V on Haiku x86_64…
A big thanks for your contribution, much appreciated! Although not finished already a big step into the right direction, hope you can stick around a bit longer to follow up on some of the remaining issues. Thanks!
