Great news that the builders are up and running again, but also that .NET is actively looking into the PR’s, thanks for your work here! ![]()
After more than 5 months, the previous pull request to dotnet/runtime has just been merged!
I’ve also opened a new PR, this one concerning native C/C++ code changes to the repo:
Haiku: Initial CoreCLR support by trungnt2910 · Pull Request #93907 · dotnet/runtime (github.com)
Weekly builds are still rolling, at least for one more month.
.NET 8 has just been released a few days ago.
Earlier today I have provided the latest weekly build for .NET 8 and .NET 9 with newly rebased code.
Release .NET 8 for Haiku x64 build 20231119.1 Release · trungnt2910/dotnet-builds (github.com)
Since I’m getting busier with other things, as planned, I will stop the weekly rebases. I will still keep the weekly builds running in case there are some breaking changes in the Haiku toolchain. However, the port will not be continuously rebased like in the past few months.
This is also a good time for anyone interested to create a recipe and package .NET 8 on HaikuPorts.
Hi @trungnt2910,
I’ve finally found some time to try dotnet on Haiku but I think the provided packages are broken or not aligned.
Specifically, I get an error installing the Haiku workload because
can’t be found. It seems the workload is not up to date with the latest sdk?
Yeah, the workload hasn’t been updated to be built with .NET 9.
Can you try it with .NET 8 packages instead?
Like the official dotnet-install.sh, my version at dotnet-builds supports a --channel argument.
So, to install .NET 8, you can run:
bash -c "$(curl -fsSL https://raw.githubusercontent.com/trungnt2910/dotnet-builds/HEAD/dotnet-install.sh)" -- --install-dir /path/to/where/you/want/to/install/dotnet --channel 8.0
If you really need .NET 9 support, you will need to add the corresponding version band here:
and enable a .NET 9 build by running another command here, passing an additional argument: --runtime-version=9.0:
Thanks!
I’m ok with version 8, I’ll try that route and let you know.
My understanding is that the workload cannot be built on Haiku, is that correct?
Unfortunately, the workload does not exist for the corresponding latest SDk. The script looks for https://github.com/trungnt2910/dotnet-haiku/releases/download/0.1.0-dev.149/trungnt2910.net.sdk.haiku.manifest-8.0.101-servicing.23631.0.1.0-dev.149.nupkg.
Any thoughts?
There’s something wrong with the build number detection logic in the install-manifest.sh file in the dotnet-haiku repo.
8.0.101-whatever should have been compatible with 8.0.100.
It should be a quick fix, I’ll try to do it when I have time…
It’s not entirely impossible to build this on Haiku. What you need to do is to port the native components of CppSharp to Haiku. The changes should mostly be build-system related, as most of the code is just invoking LLVM libraries, and we already have a LLVM port on Haiku.
I’ve pushed some fixes to this issue. A few minutes after the time of writing, new packages should have been built, along with a new install-manifest.sh script.
I’ve attempted at adding net9 support, but currently this is impossible, as workload packages are currently not versioned based on runtime numbers. Therefore, trying to build net9 alongside net8 would overwrite existing packages with net9 libraries, unless further changes are made to the build system.
the workload has been installed correctly but I now have an issue with creating a new application of type Haiku Application (dotnet new haiku).
dotnet run
/boot/home/workspace/dotnet/haiku/haiku.csproj : error NU1102: Unable to find package Microsoft.AspNetCore.App.Ref with version (= 8.0.0-rtm.23502.22)
/boot/home/workspace/dotnet/haiku/haiku.csproj : error NU1102: - Found 95 version(s) in nuget.org [ Nearest version: 8.0.0 ]
/boot/home/workspace/dotnet/haiku/haiku.csproj : error NU1102: - Found 0 version(s) in dotnet_haiku_nuget
The build failed. Fix the build errors and run again.
Apparently AspNetCore is a hard coded dependency. This also happens with other templates like “console”.
Am I missing something?
The way .NET SDK builds work is that it copies the existing SDK and updates a few files.
The existing SDK fetched by the CI script is some beta one used by the .NET team, and therefore is bundled with beta packages.
A proper, complete build script should replace these versions with the ones that are actually shipped:
My dotnet-builds repo also simulates this:
However, since we do not ship ASP.NET Core, the beta version in the development SDK is left unchanged. This causes problems when the SDK on Haiku tries to load framework packages during the first build.
Adding Microsoft’s beta feeds for .NET 8 might resolve this issue:
dotnet nuget add source --name dotnet8 "https://pkgs.dev.azure.com/dnceng/public/_packaging/dotnet8/nuget/v3/index.json"
If this does fix the problem, let me know so that I could update the corresponding instructions.
Hi @trungnt2910,
that seemed to solve the dependency issue and the application can be built correctly but an error occurs at runtime:
Unhandled exception. System.TypeLoadException: Could not load type 'Haiku.App.BApplication' from assembly 'haiku, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null'.
Abort
Kill Thread
Here’s the crash report:
Debug information for team /boot/home/workspace/dotnet/haiku/bin/Debug/net8.0-haiku/haiku-x64/haiku (3150):
CPU(s): 8x Intel Core™ i7-8650U
Memory: 23.88 GiB total, 1.78 GiB used
Haiku revision: hrev57465 Dec 19 2023 07:03:08 (x86_64)
Active Threads:
thread 3151: pthread func
thread 3152: pthread func
thread 3153: pthread func
thread 3154: pthread func
thread 3155: pthread func
thread 3157: team 3150 debug task
thread 3150: haiku (main)
state: Call (abort() called)
Frame IP Function Name
00000000 0x19c4a30e0a7 _kern_debugger + 0x7
Disassembly:
_kern_debugger:
0x0000019c4a30e0a0: 48c7c0e9000000 mov $0xe9, %rax
0x0000019c4a30e0a7: 0f05 syscall <--
0x7ff51615eb60 0x19c4a305b55 abort + 0x4a
0x7ff51615eb70 0x185178cd11c /boot/home/workspace/dotnet/haiku/bin/Debug/net8.0-haiku/haiku-x64/libcoreclr.so + 0x59311c
0x7ff51615eb90 0x185178cd492 /boot/home/workspace/dotnet/haiku/bin/Debug/net8.0-haiku/haiku-x64/libcoreclr.so + 0x593492
0x7ff51615ecc0 0x185173a09ed /boot/home/workspace/dotnet/haiku/bin/Debug/net8.0-haiku/haiku-x64/libcoreclr.so + 0x669ed
0x7ff51615ed20 0x185173f8d00 coreclr_execute_assembly + 0xc0
0x7ff51615ee00 0x115c0655353 /boot/home/workspace/dotnet/haiku/bin/Debug/net8.0-haiku/haiku-x64/libhostpolicy.so + 0x30353
0x7ff51615eeb0 0x115c0655c47 corehost_main + 0x177
0x7ff51615efe0 0x2d53b4355f /boot/home/workspace/dotnet/haiku/bin/Debug/net8.0-haiku/haiku-x64/libhostfxr.so + 0x1b55f
0x7ff51615f100 0x2d53b4417a /boot/home/workspace/dotnet/haiku/bin/Debug/net8.0-haiku/haiku-x64/libhostfxr.so + 0x1c17a
0x7ff51615f190 0x2d53b37ecb hostfxr_main_startupinfo + 0x9b
0x7ff51615f270 0x14b2a87fea9 /boot/home/workspace/dotnet/haiku/bin/Debug/net8.0-haiku/haiku-x64/haiku + 0xeea9
0x7ff51615f2d0 0x14b2a874b6e /boot/home/workspace/dotnet/haiku/bin/Debug/net8.0-haiku/haiku-x64/haiku + 0x3b6e
0x7ff51615f300 0x14b2a874d3e /boot/home/workspace/dotnet/haiku/bin/Debug/net8.0-haiku/haiku-x64/haiku + 0x3d3e
0x7ff51615f340 0x1af42fefab3 runtime_loader + 0x113
00000000 0x7fff3176b258 commpage_thread_exit + 0
Registers:
rip: 0x0000019c4a30e0a9
rsp: 0x00007ff51615eb28
rbp: 0x00007ff51615eb50
rax: 0x00000000000000e9
rbx: 0x0000000000000006
rcx: 0x0000019c4a30e0a9
rdx: 0x00007ff51615e62f
rsi: 0x0000019c4a3a406f
rdi: 0x0000019c4a3a5a08
r8: 0x0000000000000000
r9: 0x0000000000000000
r10: 0x0000000000000000
r11: 0x0000000000000206
r12: 0x0000000000000000
r13: 0x0000000000000000
r14: 0x00001097333afd90
r15: 0x0000000000000000
cs: 0x002b
ds: 0x0000
es: 0x0000
fs: 0x0000
gs: 0x0000
ss: 0x0023
st0: 0
st1: 0
st2: 0
st3: 0
st4: 0
st5: 0
st6: 0
st7: 0
mm0: {0, 0, 0, 0}
mm1: {0, 0, 0, 0}
mm2: {0, 0, 0, 0}
mm3: {0, 0, 0, 0}
mm4: {0, 0, 0, 0}
mm5: {0, 0, 0, 0}
mm6: {0, 0, 0, 0}
mm7: {0, 0, 0, 0}
ymm0: {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
ymm1: {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
ymm2: {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
ymm3: {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
ymm4: {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
ymm5: {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
ymm6: {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
ymm7: {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
ymm8: {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
ymm9: {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
ymm10: {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
ymm11: {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
ymm12: {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
ymm13: {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
ymm14: {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
ymm15: {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
Loaded Images:
ID Text Base Text End Data Base Data End Type Name
12817 0x29bf149000 0x29bf160000 0x29bf160000 0x29bf161000 lib /boot/home/workspace/dotnet/haiku/bin/Debug/net8.0-haiku/haiku-x64/libSystem.Native.so
12810 0x2d53b28000 0x2d53b87000 0x2d53b87000 0x2d53b88000 lib /boot/home/workspace/dotnet/haiku/bin/Debug/net8.0-haiku/haiku-x64/libhostfxr.so
12820 0x677b7a6000 0x677badf000 0x677badf000 0x677bafa000 lib /boot/system/lib/libicui18n.so.73.2
12819 0x68cda39000 0x68cda3a000 0x68cda3a000 0x68cda3b000 lib /boot/system/lib/libicudata.so.73.2
12818 0xacd0156000 0xacd034a000 0xacd034a000 0xacd0362000 lib /boot/system/lib/libicuuc.so.73.2
12816 0xb6d7ed4000 0xb6d81e2000 0xb6d81e2000 0xb6d8232000 lib /boot/home/workspace/dotnet/haiku/bin/Debug/net8.0-haiku/haiku-x64/libclrjit.so
12813 0xe292747000 0xe29279a000 0xe29299a000 0xe2929a3000 lib /boot/system/non-packaged/lib/libnetwork.so
12807 0xf2a6aad000 0xf2a6ce0000 0xf2a6ce0000 0xf2a6cf6000 lib /boot/system/lib/libstdc++.so.6.0.32
12811 0x115c0625000 0x115c0689000 0x115c0689000 0x115c068a000 lib /boot/home/workspace/dotnet/haiku/bin/Debug/net8.0-haiku/haiku-x64/libhostpolicy.so
12809 0x130d28a3000 0x130d28c2000 0x130d28c2000 0x130d28c3000 lib /boot/system/lib/libgcc_s.so.1
12806 0x14b2a871000 0x14b2a88b000 0x14b2a88b000 0x14b2a88c000 app /boot/home/workspace/dotnet/haiku/bin/Debug/net8.0-haiku/haiku-x64/haiku
12812 0x1851733a000 0x18517a07000 0x18517a07000 0x18517a8c000 lib /boot/home/workspace/dotnet/haiku/bin/Debug/net8.0-haiku/haiku-x64/libcoreclr.so
12808 0x19c4a2ce000 0x19c4a3de000 0x19c4a3de000 0x19c4a3f4000 lib /boot/system/lib/libroot.so
12805 0x1af42fe0000 0x1af42ffd000 0x1af42ffd000 0x1af42ffe000 lib /boot/system/runtime_loader
12815 0x207dd783000 0x207dd797000 0x207dd797000 0x207dd798000 lib /boot/system/lib/libunwind.so.1.0
12814 0x25eb3663000 0x25eb366e000 0x25eb366e000 0x25eb366f000 lib /boot/system/lib/libbsd.so
12804 0x7fff3176b000 0x7fff31773000 0x00000000 0x00000000 system commpage
Areas:
ID Base End Size (KiB) Protection Locking Name
35157 0x29bf149000 0x29bf160000 92 r-x none libSystem.Native.so_seg0ro
35158 0x29bf160000 0x29bf161000 4 rw- none libSystem.Native.so_seg1rw
35109 0x2d53b28000 0x2d53b87000 380 r-x none libhostfxr.so_seg0ro
35110 0x2d53b87000 0x2d53b88000 4 rw- none libhostfxr.so_seg1rw
35095 0x535c9b0000 0x535c9c0000 64 rw- none rld heap
35096 0x5690165000 0x5690166000 4 rw-cS none _rld_debug_
35168 0x677b7a6000 0x677badf000 3300 r-x none libicui18n.so.73.2_seg0ro
35169 0x677badf000 0x677baf9000 104 rw- none libicui18n.so.73.2_seg1rw
35170 0x677baf9000 0x677bafa000 4 rw- none libicui18n.so.73.2_seg2rw
35166 0x68cda39000 0x68cda3a000 4 r-x none libicudata.so.73.2_seg0ro
35167 0x68cda3a000 0x68cda3b000 4 rw- none libicudata.so.73.2_seg1rw
35107 0x68e0d95000 0x68e0da5000 64 rw- none rld heap
35126 0x913bd88000 0x913bd8e000 24 rw- none libcoreclr.so mmap area
35163 0xacd0156000 0xacd034a000 2000 r-x none libicuuc.so.73.2_seg0ro
35164 0xacd034a000 0xacd0361000 92 rw- none libicuuc.so.73.2_seg1rw
35165 0xacd0361000 0xacd0362000 4 rw- none libicuuc.so.73.2_seg2rw
35127 0xae3146c000 0xae31475000 36 rw- none libcoreclr.so mmap area
35149 0xb6d7ed4000 0xb6d81e2000 3128 r-x none libclrjit.so_seg0ro
35150 0xb6d81e2000 0xb6d81fb000 100 rw- none libclrjit.so_seg1rw
35151 0xb6d81fb000 0xb6d8232000 220 rw- none libclrjit.so_seg2rw
35128 0xd901051000 0xd901052000 4 rw- none libcoreclr.so mmap area
35131 0xda15526000 0xda1552c000 24 rw- none libcoreclr.so mmap area
35132 0xe15fdd8000 0xe15fdd9000 4 rw- none libcoreclr.so mmap area
35133 0xe26abb0000 0xe26abc0000 64 none libcoreclr.so mmap area
35136 0xe275468000 0xe27546e000 24 rw- none libcoreclr.so mmap area
35139 0xe278ade000 0xe278ae4000 24 rw- none libcoreclr.so mmap area
35116 0xe292747000 0xe29279a000 332 r-x none libnetwork.so_seg0ro
35117 0xe29299a000 0xe29299d000 12 rw- none libnetwork.so_seg1rw
35118 0xe29299d000 0xe2929a3000 24 rw- none libnetwork.so_seg2rw
35099 0xf2a6aad000 0xf2a6ce0000 2252 r-x none libstdc++.so.6.0.32_seg0ro
35100 0xf2a6ce0000 0xf2a6cee000 56 rw- none libstdc++.so.6.0.32_seg1rw
35101 0xf2a6cee000 0xf2a6cf6000 32 rw- none libstdc++.so.6.0.32_seg2rw
35111 0x115c0625000 0x115c0689000 400 r-x none libhostpolicy.so_seg0ro
35112 0x115c0689000 0x115c068a000 4 rw- none libhostpolicy.so_seg1rw
35105 0x130d28a3000 0x130d28c2000 124 r-x none libgcc_s.so.1_seg0ro
35106 0x130d28c2000 0x130d28c3000 4 rw- none libgcc_s.so.1_seg1rw
35097 0x14b2a871000 0x14b2a88b000 104 r-x none haiku_seg0ro
35098 0x14b2a88b000 0x14b2a88c000 4 rw- none haiku_seg1rw
35123 0x1849834a000 0x184983b0000 408 none libcoreclr.so mmap area
35148 0x184983b2000 0x18498a60000 6840 none libcoreclr.so mmap area
35161 0x18498a62000 0x1851733a000 2073440 none libcoreclr.so mmap area
35113 0x1851733a000 0x18517a07000 6964 r-x none libcoreclr.so_seg0ro
35114 0x18517a07000 0x18517a40000 228 rw- none libcoreclr.so_seg1rw
35115 0x18517a40000 0x18517a8c000 304 rw- none libcoreclr.so_seg2rw
35102 0x19c4a2ce000 0x19c4a3de000 1088 r-x none libroot.so_seg0ro
35103 0x19c4a3de000 0x19c4a3ec000 56 rw- none libroot.so_seg1rw
35104 0x19c4a3ec000 0x19c4a3f4000 32 rw- none libroot.so_seg2rw
35093 0x1af42fe0000 0x1af42ffd000 116 r-x none runtime_loader_seg0ro
35094 0x1af42ffd000 0x1af42ffe000 4 rw- none runtime_loader_seg1rw
35140 0x1c4ab3f0000 0x204ab3f0000 268435456 none libcoreclr.so mmap area
35141 0x20557dbb000 0x205ec8e2000 2436252 none libcoreclr.so mmap area
35145 0x2072e530000 0x2072e536000 24 rw- none libcoreclr.so mmap area
35146 0x2076ea14000 0x2076ee65000 4420 r--S none libcoreclr.so mmap area
35152 0x207c2dc4000 0x207c31c4000 4096 none libcoreclr.so mmap area
35153 0x207d598a000 0x207d599a000 64 rw- none libcoreclr.so mmap area
35159 0x207dca1f000 0x207dca21000 8 r--S none libcoreclr.so mmap area
35162 0x207dcf16000 0x207dcf1f000 36 r--S none libcoreclr.so mmap area
35171 0x207dcf7f000 0x207dcf97000 96 rw- none rld heap
35172 0x207dd3fb000 0x207dd413000 96 rw- none rld heap
35121 0x207dd783000 0x207dd797000 80 r-x none libunwind.so.1.0_seg0ro
35122 0x207dd797000 0x207dd798000 4 rw- none libunwind.so.1.0_seg1rw
35173 0x24de71fd000 0x24de9089000 31280 r--S none libicuuc.so.73 mmap area
35119 0x25eb3663000 0x25eb366e000 44 r-x none libbsd.so_seg0ro
35120 0x25eb366e000 0x25eb366f000 4 rw- none libbsd.so_seg1rw
35108 0x109733314000 0x1097336b4000 3712 rw- none heap
35135 0x7f2759d15000 0x7f2759d5a000 276 rw-s none pthread func_3153_stack
35130 0x7f3aea4a7000 0x7f3aea4ec000 276 rw-s none pthread func_3152_stack
35125 0x7f86f626e000 0x7f86f62b3000 276 rw-s none pthread func_3151_stack
35090 0x7fa005ad3000 0x7fa005ad7000 16 rw-k full user area
35144 0x7fda98ac7000 0x7fda98b0c000 276 rw-s none pthread func_3155_stack
35138 0x7fe7ad509000 0x7fe7ad54e000 276 rw-s none pthread func_3154_stack
35091 0x7ff51515c000 0x7ff516162000 16408 rw-s none haiku_3150_stack
35092 0x7fff3176b000 0x7fff31773000 32 r-xSk full commpage
Protection Flags: r - read, w - write, x - execute, s - stack, o - overcommit, c - cloneable, S - shared, k - kernel
Semaphores:
ID Count Last Holder Name
I think it would be better to open an issue on GitHub, in which repo do you want me to open it?
dotnet-haiku, since it is specifically related to the workload.
If this issue is also present in pure old .NET console apps, then trungnt2910/dotnet-builds or trungnt2910/dotnet-runtime might be better places.
Sadly, a crash report like that would not help much with a managed .NET exception.
After continuing on GitHub, can you please attach a .zip file containing your application project, including the generated bin and obj folder?
My two theories are:
- The workload correctly included reference libraries, but somehow messed up the runtime parts, making them not present when the application is run, or
- The binding generators somehow failed to detect
BApplicationdue to recent changes in Haiku headers.
I have reinstalled the latest build and the workload. Now a template console app runs but the haiku app fails with the very same error as before.
Installing 8.0 on top of a broken 9.0 was not a good idea, after all. It’s now the turn of your second theory, then.
As per your request, I’ve opened an issue here.
Actually, after installing the haiku workload the console application executable helloworld does not run anymore. It fails with the error:
You must install .NET to run this application.
App: /boot/home/workspace/dotnet/helloworld/bin/Debug/net8.0/helloworld
Architecture: x64
App host version: 8.0.1
.NET location: Not found
Learn more:
https://aka.ms/dotnet/app-launch-failed
Download the .NET runtime:
https://aka.ms/dotnet-core-applaunch?missing_runtime=true&arch=x64&rid=haiku-x64&os=haiku.1&apphost_version=8.0.1
Via dotnet run it works as already stated.
I’ve never tested with running the executable before. It probably has some issues with finding the system .NET installation, since 1. You are installing it to a non-standard directory and 2. Haiku does not follow UNIX directory conventions anyway.
If you really need to run something using the executable, a self-contained deployment might work, but it would take hundreds of megabytes for a single application.
A dotnet executable relies on the env variable DOTNET_ROOT to locate the runtime.
export DOTNET_ROOT=/boot/system/non-packaged/bin/dotnet
or whatever the path is, worked for me.
I was under the impression that it worked before installing the Haiku workload but I need to reinstall everything from scratch to check.
If it’s not exported by default, I’d suggest to add this to the installation script.
54 posts were split to a new topic: .NET bindings to the Haiku API
