C# bindings for some parts of the Haiku API is now available, along with basic .NET SDK support for
building Haiku applications, in a .NET workload (more details below). The source code and install
instructions are currently in this GitHub repo.
Nice progress. I will give it a try when SDK available on Haiku nightly.
On binding, CppSharp looks great choice.
I have a side project to generate binding of C++ library (especially wxWidgets) for Rust.
It utilizes Doxygen XML output as a stable meta data of the exported interface of the (cross platform) library.
I want to try it on Haiku API someday but if libclang based solution works well enough I will try that approach instead.
