This is the ninth progress report for TrackGit project. I did the following in last week.
I implemented the equivalent of git pull
. The implementation was a little trickier as there was no direct API for pull in libgit2.
The git pull command is combination of a fetch and then a merge.
In merge there are three cases:
This is a companion discussion topic for the original entry at https://www.haiku-os.org/blog/hrily/2018-07-02_gsoc_2018_-_trackgit_progress_report_9/
