I’m trying to use gpg under Haiku (R1/beta4) but so far I couldn’t get it to work. I searched through this forum and the bugtracker but couldn’t find any issues.
Generating keys does not work (for me). Pinentry and gnupg is installed. So instead I tried to import some existing keys (with - -batch) which worked. Importing without the batch option didn’t work. However since there is no password prompt (pinentry) decrypting and signing throws errors.
When trying to decrypt/sign files, gpg throws the error: Operation not allowed.
Does anybody else have these issues? If not, is there something I’m missing? Or a workaround?
Also is there a ticket on the bug tracker? If not I would open one if needed.
I don’t think there are any open bug reports but it’s been on my TODO list for like 2 years. I think the last time I looked at the problem it seemed like gpg couldn’t find an appropriate file locking method on Haiku. It wanted to use hardlinks/flock/etc… which doesn’t work so well on Haiku.
