Only one minor issue with GNOME Web ?!.. How lucky you are !..
Yepp, Web enables the most sites to be rendered most fully … actually on Haiku (32 bit I have), however since I use
→ I lost history function - it is empty … even after a reinstall attempt,
→ it is forgetting favourite pages - I did the additions for more than a dozen times - it is quite random when this hapens : sometimes after some crash, sometimes after some restart, or sometimes at a new boot of Haiku and start Web simply and face to the list is empty again …
→ result of [AltGr + other button ] combos are swallowed – happens nothing – this way for example I must copy and paste my mail address from a text file as the
‘commercial a’ *** - [AltGr + V] , for me on Hungarian layout - *** is unavailable … and the same for other important marks I would use typing in input fields.
→ also, sometimes I must close the browser to get back the imput fields’ input capability …
After a while - I do not know or understand on what it depends – the input fields on pages and in the browser itself … became “not available/read only-like” :
if empty : cannot write in it,
or the opposite - backspace cannot delete characters if they are not empty
IF I restart the browser … AFTER that they are “RW” again … I can
write in / can modify
their content in the input fields.
I can alter the URL, the search field, the data I need to give, etc …
→ and there are some also “minor” problem(s) for me - like
a) slowness, stucking of pages when I switching tabs … it is like the browser would iterate the download of the page again … painlessly long time gone when the already rendered seen page re-appears after I switched onto another tab and back again …
I thought Web would use the ramfs for acceleration … however my 20+ GB ramfs is always empty
Mount Type Total Free Flags Device
/boot bfs 13.5 GiB 3.0 GiB QAM-P-W /dev/disk/usb/1/0/2
/boot/system packagefs 4.0 KiB 4.0 KiB QAM-P--
/boot/home/config packagefs 4.0 KiB 4.0 KiB QAM-P--
/boot/system/var/shared_memory
ramfs 0 30.0 GiB QAM-PRW
/HIKVISION_2TO ntfs 1.8 TiB 295.3 GiB ----P-W /dev/disk/usb/0/0/0
/SMB Network userlandfs 100.0 GiB 100.0 GiB -AMSP-W
b) also forgets settings as well I had set earlier in Settings :
I set to ask for download directory - every time !! -
I set to magnify pages 133 % not to 100 % which is the default …
It just “forgets” them … time-to-time - I had to set it at least multiple dozen times.
c) moreover, frequently forgets the logged in statuses – meh, I can live with it … but it is annoying as of course … I should type in “verboten” so forbidden characters with AltGr , so I have to open text files again to do so , … SO-O-O … frustrating, frustrating, frustrating again …
I would be happy ,
If I would have only one minor problem again …
using GNOME Web …
