Cosmopolitan Libc makes C a build-once run-anywhere language, like Java, except it doesn’t need an interpreter or virtual machine. Instead, it reconfigures stock GCC and Clang to output a POSIX-approved polyglot format that runs natively on Linux + Mac + Windows + FreeBSD + OpenBSD + NetBSD + BIOS with the best possible performance and the tiniest footprint imaginable.
That’s impossible. Even if such a format would exist it can’t have best performance and even less tiniest footprint.
Greetings
Peter
The format does exist, it uses severall hacks… and then functions as a mostly fat binary afail.
Not sure where the claim of best performance or ti iest footprint come from…
It’s not impossible it’s just seldom practical. It just requires a linker library to a generalized runtime for text-only apps. Going any deeper than that requires a bigger runtime library.
Ok, I looked at the webpage describing APE , and it seems that such a format exists. That’s quite strange!
Greetings
Peter
That APE crap again?
… Some stuff never dies…
