Hi, i’m going to write a driver for my d-link dfe-690txd pcmcia ethernet card (it is based on a realtek 8139 chip).
I’ve written a simple program in C that scan the pci list and return a list of vendor id and device id and (if found) the irq of the d-link card.
However, when compiling the program gcc output the following:
/tmp/ccilfp64.o: In function `main':
/tmp/ccilfp64.o(.text+0x2a): undefined reference to `get_module'
/tmp/ccilfp64.o(.text+0x2a): undefined reference to `put_module'
collect2: ld returned 1 exit status
I’ve tried to compile this code with a makefile, then manually with gcc, also using -lroot and/or -ldevice. Results doesn’t change.
If i compile it with the “kernel_intel” as an object passed to gcc (or as a library), the compiler error disappear, but i’m unable to execute the produced output file.
(I’ve also checked if this could be a permission problem, but the execute bit are all set).
Could you give me some suggestion on how to resolve this (or where i can read something in order to resolve the problem myself)?
PS: Sorry for my bad english.
Greetings,
Domenico.
medevil wrote:Hi, i'm going to write a driver for my d-link dfe-690txd pcmcia ethernet card (it is based on a realtek 8139 chip).
I've written a simple program in C that scan the pci list and return a list of vendor id and device id and (if found) the irq of the d-link card.
If i compile it with the "kernel_intel" as an object passed to gcc (or as a library), the compiler error disappear, but i’m unable to execute the produced output file.
Greetings,
Domenico.
Right now this forum is probably not the best place to post "driver development" questions
If you have the Haiku source already, I would highly suggest you look through the Haiku network drivers, and use them as a starting guide (you will want to use jam and the Haiku build system):
http://www.haiku-os.org/wiki/index.php?title=Getting_Haiku
there is an rtl8139 driver already in the repo - I don’t know how complex a PC-card driver is, but maybe you can add your informatino to the existing driver. I’m not sure Haiku has complete PCMCIA bus support yet either.
http://svn.berlios.de/viewcvs/haiku/haiku/trunk/src/add-ons/kernel/drivers/network/
Finally, it would be much better for you to ask driver development questions on the mailing list (I would recommend the network team list for now):
http://www.freelists.org/list/openbeosnetteam
