Get current workspace #?
The Workspaces applet lets you specify the number of a workspace to jump to:
Workspaces 2
But for that to work in a script, you’d have to know how many workspaces the user has and which one you are currently in.
There is a utility (“workspace”) for that on Beshare, but it doesn’t compile in 64-bit Haiku.
Is there another way to get this information?
EDIT: attaching link to file
Is the sourcecode for the workspace utility online somewhere?
Besides that, you could try if the Workspaces applet can be asked for the currently active workspace with hey. I would have tried myself but I’m not on a Haiku machine right now.
It’s in the hpkg, in the data directory
You can get how many workspace there are from the settings
message ${XDG_CONFIG_HOME}/system/app_server/workspaces
with a pinch of gawk you can do rows*columns to get it
message ${XDG_CONFIG_HOME}/system/app_server/workspaces | awk 'BEGIN{i=1} /columns/,/rows/ {i=i*$(NF-1)} END{print i}' FS='[^0-9]'
I don’t know how to get the current workspace, perhaps with a trick, opening a new tracker window and getting its workspace with hey
hey Tracker get Workspaces of Window $(hey Tracker count of Window | awk '/result/ {print $4-1}') | awk '/result/ {print 1+log($4)/log(2)}'
Thanks, zuMi, that actually gives parseable output, But it would be a maintenance nightmare for me :unamused:.
For the record, I found out that there are undocumented features in yab that give me exactly what I wanted :smile:. I’ve reported it here.
