Hello, I installed Beta 5 and have been trying updating some haikuports recipes. I managed to make a working recipe for GemRB 0.9.3, which seems to compile and run fine… well, mostly
There’s a python script in the source, “extend2da.py”, which is also provided as a command by the Haiku package the recipe makes. Cmake doesn’t seem to find/handle this script properly in the build process or something, I’m circumventing that by moving & replacing stuff around during the build process (in the recipe’s BUILD() block) since I don’t know the proper way to fix it.
Even with this workaround, the script file doesn’t work as a command anyway, it cannot find python I guess shrugs
I made a Dropbox folder with the recipe + additional files needed and the pre-built packages.
So… questions
Any idea how to fix that build issue in a cleaner way?
How would one submit an updated recipe to the haikuports github? You just make a commit or there’s something more about it?
Should a hacky recipe like this even be submitted to haikuports?
For the game’s icon I’ve recolored zumi’s Ruby icon but I vaguely remember GemRB had its own HVIF icon once, does anybody have that one lying around?
Yeah, done it already, that’s one of the first things I had to fix when making the new recipe, build would fail way earlier otherwise
EDIT: Or maybe you mean that the python script is trying to use python instead of python3? That’s entirely possible, I’m pretty sure that script isn’t being processed during build or something
Did a quick check, using python3 in the script works and the game (demo?) launches.
A few things could be done by using sed, and a small change to find SDL2 can be done so you don’t need to use the hardcoded paths for it (which will fail as on 32bit those can be found in “/boot/system/develop/headers/x86/SDL2/”
In there recipe sed for python3
PATCH()
sed -i 's,\/usr/bin/python,\/usr/bin/python3,g' admin/extend2da.py
Alright, thank you for the help, I’ve updated packages and recipe in the Dropbox folder so the game compiles and the script can be executed as intended. I didn’t integrate the SDL patch as simply copy/pasting it makes git worry about patch version or smth so I guess I’d have to remake it locally using diff.
Feel free to improve upon the recipe and put it on haikuports if/when it’s appropriate
Was already strugling the first time I tried to grab the files Feel free to create a PR for this, can’t do it all for you, but I’m willing to help (and I’m sure there are plenty in the haikuports team that can assist)
