Hello people,
anyone have experience with Geekom mini PC? I want to install Haiku to this PC in order to make it as main Haiku machine, but the USB stick does not start up.
GEEKOM MiniAir 11 Mini-PC Intel Celeron
I will try to change the msata to a msata with haiku installed to test at home, but someone have some info to make it runnable without this step?
camtaf
July 25, 2023, 5:18pm
That looks remarkably like my MSI - maybe try pressing the ‘delete’ key (or F2) when booting to access the UEFI/BIOS…
Thanks for the answer, i do all of this and changes in the bios too. But does not start from usb stick
To isolate things first, are you able to boot from a usb stick with a windows 10/11 image ?
camtaf
July 26, 2023, 8:31am
5
If you can access the UEFI/BIOS, you should be able to change the boot order…
…or it may have USB boot turned off.
I have changed the boot order in bios. I need to try ma win10 stick to test if this is loading.
tqh
July 27, 2023, 9:48am
7
It is also good to try a different usb-stick (preferably one you previously managed to boot other operating system on that machine).
My Haiku install stick runs perfect with other machines. I need to make more tests.
