Funny Thing with CVS Checkout
Hi.
I’ve done a checkout on the CVS source for Haiku by following the guide at http://haiku-os.org/learn.php?mode=nsl_view&id=52 .
But on that image (screenshot) says that the size is ~550 Mb for 15695 files.
I got 140 MB (147.250.905 bytes) on 19.331 files and 2.143 folders.
Did I get the full thing? (I used both CVS commands).
Is it because I used WinXP to download the CVS (NTFS, cluster size?)?
It gave me no errors and was preety fast on a 1mbit dsl connection.
What happened? Didn’t I get it all or are the haiku kit teams doing a wonderfull job shrinking the code? :smiley:
Thanks for everything.
Marcos Alves.
X wrote:
Hi.
Yes, you probably got everything
No, because BFS clusters are smaller than NTFS ones, anyway...
Quote:
What happened? Didn't I get it all or are the haiku kit teams doing a wonderfull job shrinking the code? :D .
The 600MB is when you’ve built it all as well - the source gets the objects and the binaries added to it.
Thanks MYOB for the Quick and Nice Reply! :smiley:
noobs :roll: :oops:
