So I guess my question is, then, why isn’t the Makefile Engine doing this by default? It’s supposed to take the hassle out of things, after all. Where is ‘$(CXX)’ that it uses defined? Actually it looks as if it always uses $(CC) for LD, anyway.
And are there any docs? Anywhere? Can’t find them.
The makefile_engine was adapted from some BeOS version (not sure where it comes from). Initially it supported the Metrowerks compiler for the PPC version and I guess that explains why it is made this way, but I can’t be sure, never having used PowerPC BeOS myself.
Not baby steps anymore, perhaps - I needed a way to set geolocation on some of my photos and found a workflow that works for me. Attribute Editor a bit less generic, can we have an attribute display type for Location, please?
I think I need to create a new Map application using openstreetmap tiles to make this work the way I really want, though.
A great native Haiku app for photo collecting would be nice thing to have.
With all those nice attributes.
Maybe some kind of Family - Ancestor - Autosort (by parents, childs, grandfater, ant and Uncle and so on…), maybe possible with attributes?
I had to try out setting attributes using xicon. Using the following script you just name the xicon file “[attribute]=[value]”, make as many copies of it as you want and drop the images to the appropriate xicon file. Note that it is set to only modify string attributes:
cd $FOLDER_PATH
for x; do {
attribute=$(basename “$0”|cut --delimiter = --fields 1)
value=$(basename “$0”|cut --delimiter = --fields 2)
addattr -t string “$attribute” “$value” “$x”
} ;done
I have a few ‘xicons’ that do things like that, like “ShowAttr” that displays all the attributes of a file. I’d post it here, but I realize it uses another app of mine (that does some string extraction) that I don’t imagine anyone else has…
yes that will be another useful demo, but a howto would be nice, at least a link to a help file how to use the program and where to find the sample files. Because it is a real useful application. I need to learn more about attributes then…
