In fact, I kinda like circles for displaying status of a thing the user has no control on it because it is visually neutral.
At the opposite, a checkbox is visually an invitation to modify the attribute. It let the user think that putting a notch there will have directly an effect on the file or further behaviour.
But the circles look like radio buttons, actuallyâŚ
Tracker does work with the âCheckboxâ boolean attribute. Please have a look at the Extra attributes section of the filetypes etc. workshop of the user guide. To quote the essential parts concerning a boolean attribute:
Boolean for binary data: 0 (false) or >=1 (true)
- Checkbox - Can be used to show either one of two symbols, see Special below.
- Special - Defines the two symbols used for a checkbox display. For example, âxoâ will show a âxâ for all values >0 and âoâ for 0.
So, instead of the âxâ and âoâ, you can scour CharacterMap for suitable symbols.
The nice thing is, that this is on a per attribute basis. You can create one bool attribute that shows the special characters âxâ and âoâ, and another showing an empty and full circle, or checkmarks or anything else.
To illustrate:
Note: To see the changes, youâll have to hide and re-show the boolean attribute in the Tracker window.
Thanks again Humdinger, should have read the User Guide
Booleans will always be BCheckBox in the new Attribute Editor Iâm toying with - I want to edit tags, description etc directly in ShowImage (code is dynamic and will work for MediaPlayer etc as well):
Width / Height should not really be set as editable in FileTypesâŚ
Btw, you found a nicer symbol for a radiobutton true value. I could not find the code for this symbol, do you by any chance remember it?
Itâs in the âGeometric shapesâ of the Noto font.
â = \xe2\x97\x89
â = \xe2\x97\x8b
â = \xe2\x97\x8e (fits maybe even better?)
I just came across an index_server add-on in Haiku src/add-ons/index_server but it wonât compile since itâs referring to a non-existing include file audioproperties.h. Seems to be dormant, too, last update is from Oct 28, 2010.
There was a CLucene analyzer for fulltext search, and an audio tags analyzer.
Would be great to reboot and extend this effort, any updates on this endeavour?
Well your research accurately shows the current state. This is clearly not on the TODO list for Haiku R1 and we are focusing our efforts on more important parts (web browser, drivers, printing support, bugfixes, âŚ)
As usual if someone starts work in this area we will review patches and accept them if appropriate ![]()
I understand, but Iâd really like to see this in R1.1 as it enables a variety of applications and thus is really more a central infrastructure service (Iâd certainly love to contribute as it directly relates to my side project Iâm now actively working on, finally).
Maybe put it in /attic, unmaintained or at least update the README until it gets more attention, as anything in the haiku/src tree should build imho.
Well, âatticâ is innapropriate for things that are not complete yet, and in general this is not how we do things mainly because it makes the history more annoying to track with git when files are moved around.
As I said, if you want to work on it, we accept patches, and if it works well enough weâll include it in the system.
Sorry â Iâm late to this discussion, not having been following the forum recently, but I guess i should chime in!
Does nobody know about âxiconâ any more? An app that I wrote in the age of BeOS to run shell scripts from icons. Iâm not sure what percentage of my day uses it, but itâs large! My Desktop is littered with xicon icons, from simple ones I just click on to read the BBC or fire up Ruby to ones that you drop files on to process them, such as âShowAttrâ that uses listattr and catattr to display all the attributes of files.
I suppose itâs my fault that Iâve never pushed to get it into HaikuPorts â which seems the only way an app will ever be visible to the world. Itâs just that the old zip file is still perfectly adequate!
In any case, hereâs its current location:
http://goodeveca.net/beos/xicon.html
Back to the topic of photo attributes, I even have a script that uses âexiftoolâ and my âgadgeteerâ (which someone has added to HaikuPorts) to edit the exif data of a file and add a âCommentâ attibute (which was all I wanted). I could pass this on, but itâs rather tailored to my own needs.
So now itâs my turn to say sorry for not getting back to you - xicon would make a lot of sense here and more manageable for a larger collection of scripts. Gadgeteer also looks really interesting - I tried to build both on my x64-install of beta2 but sadly didnât manage to get them to build (the haikuports-recipe for gadgeteer is for 32bit only).
Ackk â yes. I suppose there might be problems switching to 64-bit. Not sure what they would be, though, as i have little interest in switching myself. My Linux Mint partition is 64-bit, and I notice no difference except that apps from my old 32-bit Ubuntu wonât run!
Do you have any hints as to what fails? I suppose it might just be the newer gcc. Theyâre both gcc2. Gadgeteer uses libYAML, which I just built in as a static library. That would have to be rebuilt too. Iâll have to look at the HaikuPorts recipe, (I didnât create that.) When I get a chance, Iâll see if at least they compile with the new gcc.
For xicon, I just get a few undefined references to âoperator deleteâ and âoperator newâ, as you say may be related to gcc version but I have no clueâŚ
You should use g++ instead of gcc.
Hah! (and Ha HaâŚ
) I had just tried to compile xicon with gcc8 (setarch x86 in 32-bit) and got exactly the same error! A quick visit to the mailing list and Waddlesplash sorted me out.
In the Makefile, just add a term to the LIBS= line:
LIBS= $(STDCPPLIBS) be
Try that, and see if thatâs all 64-bit needs. (I got a couple of warnings, too, but I ignored them for now.)
Thanks!
Whatâs the (specific) difference? (Xicon just builds with the Makefile engine.)
Well, that was embarrassing (not having a clue why new / delete gave errors
), but YES now it compiles and runs just fine! Thanks a lot!!!
When you link using g++ instead of ld, it adds the C++ libraries automatically. In the context of the makefile engine, the change you did to LIBS is equivalent.
Index Server itself build, index_server will not work, from what i recall, because it will index the own index recursively
So excluding files & paths are missing (and therefore a setting gui and backend)
you tried to build all addons there, the audiotags plugin is broke because i think it requires taglib (audioproperties.h Source File (TagLib)) so you need have installed https://depot.haiku-os.org/#!/pkg/taglib_devel/haikuports/1/11/1/-/4/x86_64?bcguid=bc173-WAFF (i guess this should be added to the jam file somehow⌠but i am a noob there ![]()
