Fully-compatible laptop for Haiku?
Since the last thread specifically on this topic is from 2010, I think it’s probably OK to start a new one. :slight_smile:
I had lost track of Haiku, and only recently found out that the “only run it un a VM” recommendation had been dropped, so I really, really need to get a laptop to run it on.
From reading through the available material, and looking through eBay, it looks like the ThinkPad Carbon X1 is a good candidate, but I’m unsure about how recent a generation of the X1 would be fully compatible.
There’s a thread here from this summer that mentions a gen9 doing well, but no details. The gen7 is extremely reasonably priced on eBay, so that seems like a good bet.
Does that seem reasonable? Can anyone speak directly to what the latest fully-compatible generation of the X1 would be?
(I am really psyched to try Haiku on hardware; I was really sad when I finally had to move off BeOS.)
Might want to be more specific about “fully compatible.”
For example, if the trackpad can move the cursor but can’t “scroll”, is it working, or not working? Web camera? Sleep?
Welcome @us3r1d
There is an unofficial list: Haiku Hardware Database
Fair enough. :slight_smile:
I’m thinking “supports every piece of hardware that is in the laptop and has support in the OS” is the ultimate goal, though I guess (as you point out) I’m not really interested in all of it?
I actually don’t know to what degree Haiku supports things like multi-touch on trackpads at all, so it’s hard to say in advance. I certainly don’t care about anything on the trackpad other than moving the cursor and tap-to-click; I don’t care about built-in cameras either.
Hi michel,
Thanks, I did look through that.
None of the entries are dated, so I’m not certain how current the comments are; comments saying stuff doesn’t work could be from any time and may have been fixed long ago. I’m guessing that “Hrev” means “Haiku version” and refers to the nightly build numbers? (In which case they’re mostly from several thousand builds before current.)
It seems that site’s best used to verify that at least no problems I care about were reported for a specific machine before I try it. :slight_smile:
It’s hard to really nail this down in advance. For example, looking at a complaint about a T460, the wifi card is idualwifi7260 - like mine. But listdev shows a different revision number (?) than mine, and I have firmware files and he doesn’t. Typical ebay ad isn’t going to drill down to this level, and in general it wouldn’t do you any good anyway.
Buy virtually any old Thinkpad (T, W, P, or X preferably) made in the past 13 years and Haiku will run well. There is no need to spend a lot of money because even a T61 from 18 years ago is as snappy running Haiku as a modern laptop running Win 11. Of course it won’t run HD video very well.
I was happy with the perfomance of my T430 (2012), but you might prefer something slightly more recent, like a T480 or T580 (former has 14 inch screen, latter has 15 inch).
The point about Thinkpads is that they almost all had and have great support for Linux, and tend to support Haiku well too. Bear in mind that “well” doesn’t necessarily mean perfect.
ThinkPad T460s, T430, T430s
My T460s has a 2560x1440 screen, looks beautiful
Are i2c trackpad devices supported now? I haven’t noticed any news on that.
If not, then you have to sort out which laptop models have this, including Thinkpads.
I can recommend the Thinkpad x1 Gen 9 for Haiku. Did not wrote a Review because there is already one which is very good.
The trackpad still does not work. The red button in the Keyboard does work.
The Gen 9 has a nice 16:10 screen which i like very much.
Someone is working on a i2c driver, but i dont know the status, one reason i have the T460s for haiku, Trackpoint and Touchpad work.
There is a driver but it’s far from working everywhere.
It looks like the gen7 is when the trackpad went to i2c, according to this page: OpenBSD on the Lenovo ThinkPad X1 Carbon (7th Gen) - joshua stein
So I think I’ll go for a gen 6; costs about $50 less anyway. :slight_smile:
Yeah, the ArchLinux wiki says the 6th gen uses the psmouse driver but the 7th gen uses the i2c driver:
So 6th gen looks like the best bet for an X1 Carbon.
Thanks for the responses.
That what i meant, T460(s) Touchpad works T470+ does not,
T560 Wlan did not work, T460s does
