Do you have IPv6 configured? (there is no autoconfiguration or DHCPv6)
The other main issue with IPv6 is that Haiku doesn’t support Path MTU discovery (this also affects IPv4, but is a bigger issue with IPv6, particularly if you are using a tunnel for IPv6 connectivity)
After you have manually set up an address, things should work, but I have not done much testing. I think the other problems in the IPv6 stack have been solved, but I didn’t try it myself recently (I guess I should figure out how to set my machine with an IPv6 address, it would be nice if it could do it automatically)
I thought I had ipv6 when I’ve looked in the ifconfig or with some ping, but indeed I’ve just tried again with ping6 and it says “network is unreachable”. I don’t know what data to enter to configure ipv6…
