I currently can’t make a screencap but I get some weird fonts when starting the arduino dev suite on haiku 64 bit beta 2. Every text looks like ??? ??? ???. Any suggestions?
many thanks
many thanks
Yes it’s a known bug in the Java port which hardcodes a font we no longer install by default. Try installing the dejavu package, I think it’s this one.
I don’t know which font it is, but I downloaded a number of fonts and found the Arduino editor works fine now. However, I need to program a Pixel and needed extra libraries. I was able to add them in Windows but can not figure out how to do it in Haiku.
On the other hand, I find editing text to be nicer on a Haiku system, if I could figure out the library problem it would be another program/environment I never would use Windows for.
I think @PulkoMandy uses it, he probably knows where those libs go.
I don’t, I use only avr-gcc with my own makefiles.
3deyes is using it too, maybe he has an answer.
As @mmu_man mentioned you can use pkgman install dejavu
is a workaround for now.
Rude…
Ouch! Fixed
Thanks, this works fine.
