Hi,
Do you know if fltk lib are ported on haiku?
Regards
pkgman search fltk ![]()
It is marked as untested:
Haven’t checked it in a while, but it should still build and launch ok.
You may want to check also these:
https://www.fltk.org/str.php?L3513 - for FLTK 1.4.x.
https://discuss.haiku-os.org/t/fltk-port-was-port-debian-package-management-system-to-haiku/2996/37 - initial work by @mmu_man.
https://twitter.com/mmu_man/status/683275806429306884 - some screenshots.
great! thanks all.
How to close this subject on this forum ?
Has it been resolved?
I haven’t rebased it for a while but last I tried at least one branch was working not too bad. Not sure where they are at now in terms of current branch. I can see if I have my latest work pushed somewhere. At least please don’t restart from scratch.
It’s your (ground) work, not touching that ![]()
I wouldn’t mind you taking over, just would like to avoid redoing stuff
It takes a developer to do those changes
I saw through internet aaa lot of fltk great scientific program.
Advantage of this library is fast and easy to use.
It doesn’t use a lot of dependances.
And use 3d opengl. (Maybe for teapot)
One of the main advantage for haiku is to attract this very smart community.
That’s why if fltk work on haiku, it’s a chance to increase community.
Unfortunately, IIRC OpenGL in FLTK on Haiku was not working last time I checked it.
