First enhancement proposal on apps :)
Find my first enhancement proposal for Pe :
The default find selection is now visible :slight_smile:
I don’t know why the initial choice is to have a square, which make the find pattern very very hard to see with the default color scheme.
Waiting to see if the repo (HaikuArchives) is open to PR :slight_smile:
Now checking for an easy enhancement or bug fix proposal to test my first commit on Haiku repo…(Icon-O-Matic, others, … will check the existing tickets for easy tasks)
Maybe this for Icon-O-Matic ?
It’s a first shot, as the remove must be a single menu (and not remove>remove).
Hmm, adding a remove option to the Transformer menu… interesting. I guess, why not? May as well make the menu show all of the actions that area available on transformers. Bonus points if you can make the remove menu item show the del shortcut :slight_smile:
Ok I’ve been able to do my first commit for Icon-O-Matic for review :slight_smile:
It’s quite basic with the addition of “Remove” menu for transformer, but it’s a feature I didn’t find when I tried to remove one when no more needed (or added by mistake)
2025-01-03_11-35
Why isn’t this in a context menu when you select an item instead? This seems really wierd UI wise.
The combobox will obscure items it would act upon.
Yes I have the same feeling about the existing menus too.
This commit was not intended to change the current ergonomics (which can be improved) but rather to just add a basic feature to test my setup.
I will adjust according to the reviewer feedback
Merged! Congratulations on your first patch :slight_smile:
I know a little more about the workflow now, so the door will now be open to others ideas on others parts of the system :slight_smile:
I have reviewed the whole process and the details should be available in one week on Haiku Insider, so it might give ideas to additional people for contributing.
This one should be quick to resolve :
I will check how to enlarge the initial size and maybe provide a label for this field
Inline editing may make more sense here
