Finally got good laptop for daily driving Haiku
Hello!
I have been using Haiku a pretty long time, but always in some virtual environment or too old/slow hardware, so daily driving with it wasn’t really possible/pleasure. Basically web browsing was the main reason, because it requires nowadays quite a powerful machine.
Couple weeks back, i started to think that maybe i should buy dedicated laptop for Haiku. I started to research Haiku hw database, this forum and asking AI about some things. I noticed that some Intel based Thinkpads and Latitudes was pretty good in reviews and those have best compatibility. A couple days of Ebaying and found this from AMSO.. :nerd_face:
Lenovo Thinkpad T460s with i5-6300U cpu, 8Gb ram, 240Gb SSD, 1920x1080 display, finnish keyboard layout.. and of course a working battery, but this has only one battery inside, second have been removed. Main battery have 82% of capacity left, luckily it is OEM Lenovo battery.
It came with Win10 Pro FI and i tested hardware and battery life with it, basic browsing and some youtube videos got about 4,5 hours of battery life. Laptop is pretty good shape, no cracks anywhere, screen has couple of marks from trackpoint buttons, but it doesn’t really bother me.
Everything was working good, so i gave Windows a exodus and installed Haiku R1Beta5 to it. I made UEFI install and partitioned SSD in three partitions, EFI, HAIKU and 50gb MyStuFF where to store important files. It worked pretty good out of the box, but trackpoint and touchpad was a bit problematic, sometimes another worked and another didn’t, just randomly. I upgraded OS to latest nightly and it gave some more options to adjust mouse settings and now it is pretty good and usable. Still sometimes trackpoint doesn’t work..
Battery life is, well not good as in windows, but Haiku drains battery about 45% per hour in basic browsing, so i get about two hours of battery life. I will probably buy that another battery later, maybe from iFixit eu-store, it costs 65€ with postage and they seems to have pretty good reputation/quality. With it i should get maybe 4 hours of battery life.
I tried it also with Ubuntu 26.04 live usb stick, i installed tlp and checked battery wear/info with it and then calibrated battery in ubuntu, got couple of percent more capacity with it. I tested also battery life in there with same kind of browsing and i got 2 hours 45 minutes of battery life in balanced mode and display brightness about 50%.
With “sudo tlp-stat -b” command i noticed that there was battery charging treshhold limits, which were 0% to 100%. I read from internet that those limits are stored in chip, so ran “sudo tlp setcharge 75 80 BAT0” and checked again and limits changed. I rebooted ubuntu live and checked values again, and they were still 75% and 80%.
Then i booted to Haiku and voila, same charging limits are used in Haiku too. Why i did this, well i probably keep this laptop sometimes in charger for longer times, and this now keeps battery charge maximum 80% all the time and it only starts charging below 75%. I hope this old battery lasts a bit longer in this way.
A bit long post, sorry about that, but i am VERY happy with this laptop! :smiling_face_with_sunglasses:
Finally i really can daily drive Haiku! It even plays Youtube videos in 1080p with Iceweasel, how awesome is that!!! (Btw. it plays 1440p videos also in youtube, without dropping a single frame, but fan spins pretty fast then!)
Thank you developers!
I have the same Laptop, but with 2560x1440 Display, that make a huge difference, the fonts and icons look stunningly beautiful.
Highly recommended
Everything but Webcam and fingerprint reader works
Yes, that is true.
With my eyes this fullhd is enough for me. :face_with_monocle:
I was wondering that sim tray which seems to be installed. But I didnt see LTE modem inside, so maybe that was option back then. Antenna cables were taped in place where i think modem should be.
Huawei ME906s and Sierra Wireless EM7455 may be the modems which are supported.. not sure however.
Probably no LTE support in Haiku yet..
My eyes aren’t that great either, but i really makes a difference, just as a hint for anyone looking to buy one (those dispolays are hard to find, though)
Have fun
PS Haiku also works on my “Work” Laptop T14gen4, but only the trackoint, not the touchpad
Okay, nice to hear. :grinning_face:
I had couple of t460s options, and one was with 1440p display, but i was thinking, maybe that drains battery more and i dont really need it. Another option was 1080p with touchscreen, but it was glossy display and i like matte more.. and i dont need touchscreen.
I also had t480 as option, but just those possible touchpad/trackpoint problems and also those were more expensive.
I really like Haiku’s simplicity and lightness. No bloat etc.. i found “almost” all software i needed to it. Trying to use native apps as much i can..
Have been using this Haiku laptop almost every day and it is good for almost any daily task. Updated it to latest nightly which broke Bluetooth. And Iceweazel seems to hang more often now, but web+ works a bit better now..
A still need to get that second battery, now with only one battery sometimes I got to hurry to find charger.
Couple of friends tried Haiku first time and they loved it. They are searching compatible laptops now for it. Sadly there is no up to date, easy to search hw-database, so they started to make one..
If you do not move your laptop the whole day constantly, then you do not have to take care battery drainig, it can be plugged in permanently, then you can have any HW option.
Do you need it as you need the laptop on field or meanwhile trafficing ?
In my 2013 Dell laptop I could set in UEFI BIOS to leave battery without charging/discharging and works directly from the power adapter. I would enable back as if I would go out traveling and I maybe cannot use power from power outlet on the train or other places where I would open the lid to boot up.
For an old cheap old laptop, the Dell Latitude E7240 works fine. Graphics/wifi/sound/trackpad/keyboard all work out of the box. The screen resolution is pretty low (not a Haiku issue, it’s just a old small screen).
Actually i had some of those Latitudes in mind too, but finally choosed Thinkpad.
Couple days ago I tried to make some librecad tutorial video with Haiku. In Linux i usually use OBS Studio, but because it haven’t been ported to haiku yet, I recorded audio with Audacity and screen with BeScreenCapture and i mean both at the same time. Edited video in OpenShot and exported it to mp4. It worked pretty good.. i was a bit suprised.
I had to use USB sound card for headphones microphone. There was some background noise, but after recording I added some filters in Audacity and result was pretty good.
I will probably make more videos with Haiku..
Would be a great thing to have a tutorial about your workflow, as Text or as Video…
I could imagine many people will love to know this tricky thing to do on HAIKU.
Why Audacity? Is there no other option to use the microphone?
Would be great to have some BeScreenCapture with Sound option.
But your solution will work right now, thank you for some insight on that matter.
Great to know:
So it would be great to have UVC Webcam 1.0 working!
Webcam 1.0
Audio via Webcam!
Just upgraded from couple months old nightly to beta6 and this t460s is still working good!
Thanks to all devs!
Hi,
I’ll gladly accept patches to add sound recording to BeScreenCapture.
2 posts were split to a new topic: QCAD 3.33.0 port
3 posts were split to a new topic: LibreCAD port
Wrong thread?
I moved posts about QCAD and LibreCAD to dedicated threads to avoid mixing feedback on a laptop being supported by Haiku with software ports.
I did get a bit bored today and wanted to play some fps game with Haiku. I tried a few games, but none of worked, and then i found EDuke32 and thought, let’s try this one. Copied necessary file to it’s folder and..
Hooray, it worked and was perfectly playable.. fps was very good and everything worked fine. :smiling_face_with_sunglasses:
I have been Duke Dukem fan since it was released, very cool game..
I found some cool voxel mod for it, which worked fine too.. and oh yeah! I played it couple of hours and was very happy! :star_struck:
Going to play a lot in future too.. :slightly_smiling_face:
Yes! I daily drive haiku on a dell inspiron 5300 with an i5-8365u, and you should probably consider using Firefox instead of Iceweasel too! Glad you’re happy with your setup : )
