Hello all; im trying to convert an ogg music file to mp3 (i do exactly the same as in my linux box) but ffmpeg in haiku, says that selection of encoder fails. Can anybody make it to work or its a bug?
thanks,
n
thanks,
n
If same command is working in Windows or Linux/FreeBSD than it is likely Haiku port bug and it should be reported here: https://github.com/haikuports/haikuports/issues.
No success with freac; thanks @brunobastardi.
As @X512 recomend, the bug was reported here: https://github.com/haikuports/haikuports/issues/4841
Hi there, after the report @diversis fix that. ffmpeg its convering to mp3 ok now.
QMplay2, download and convert too!
